Question about Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2 cycle Gas Engine 18" Chain Saw
Pull cord will not retract - Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2 cycle Gas Engine 18" Chain Saw
    Sergeant:
  • 281 Answers
Sounds like the rope is caught between the rope pulley and the housing that covers the recoil spring and pulley.You will have to remove the housing that has the recoil spring in it.Be careful of the rope at this point because if this is the problem the rope will want to rewind as soon as the housing releases the rope.You should be able to inspect the rope for frayed spots.If you need to replace the rope,pull it out till you see the spring and clamp it with a pair of needle nose vice grips. If this is anything else in this area it will be a part replacement. Well hope this helps.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 22, 2011
  • donm1 May 22, 2011
    thanks, it is not caught. I have removed the cover, the rope is fine. there is no tension on the rope even when you rewind by hand. the spring does not appear to be broken.
  • Darryel Hubbard
    Darryel Hubbard May 22, 2011
    Sounds like you need to check the socket that the recoil spring mates with to start the saw some times they get striped or if the spring stopper is broke so that the spring just turns in the housing and never contracts could be a possibility.
    http://www.partstree.com/parts/?lc=troy_... some parts numbers
    http://www.jackssmallengines.com/replace... lots of videos here.
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
remove the recoil section and replace the broken spring
Aug 07, 2016 | Garden
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Problem with retractable cord on hand mixer
Hi Sandy
Retractable cord mechanisms, after a while, can get a bit dodgy, especially with things like mixers where there may have been years of accumulated batter, frosting, bread dough, or what have you that got splattered on the cord and subsequently sucked back up into the retractor reel. They typically have an inertial ratchet that lets you pull out, but sticks on retract, unless you pull the cord all the way out to reset.
Before starting, cardinal rule is:
Always unplug before working on electrical stuff. If it's already acting up, you don't need to discover a short or a bit of bare insulation by shocking yourself or starting a fire.
With it unplugged:
  1. Pull the cord out as far as it would normally go. Depending on the exterior, give it a wipedown with a cleaning towel and a surface cleaner like simple green or windex. See if it's looking like it's coughing crumbs out of the cord hole as you pull.
  2. Let it retract all the way, then pull all the way back out. After you have a bit of cord out, pull it a short ways at higher speed, then let it retract back in, solid quick pull, slow retract. You're trying to get the ratchet to re-engage if it's gotten stuck or gummed up.
  3. If you can't get any response the above, you may have to consider whether you want to take it apart. Use a search engine to look for 'My mixer make/model service manual', or 'How to replace cord for my make/model mixer'. Likely as not, someone can go through replacement, which will give you the steps to open it up and just see if it needs cleaning. And, if something has just broken, you'll be in a position to replace it.
  4. A final thought - if it's working fine, and it's just an issue of the retracting cord pulling at the mixer as you work, you can also use a temporary cord-hold. You don't want to do anything that could pinch or cut the cord, but something like a medium sized binder clip, perhaps with a fold of tower inside , can be clipped onto the cord right where it emerges from the mixer, after you have enough cord out. The binder clips are cheap, pretty strong. and not likely to pop off without a deliberate re-opening when you're done.
Good Luck!
Nov 20, 2015 | Food Mixers
Bissell Hard Floor 1161 Bagless Canister Vacuum cord won't retract
You have to find a way to turn the drum the cord rolls up onto. Just move it par enough o allow it to retract. Hopefully you will hit that point before the spring lets go.
Dec 21, 2014 | Bissell Vacuums
Problems with pull cord ,pull cord not engageing,pull cord is slipping freely.it acts like a bad spring on a briggs,but iam not familiar with this make.
Pull cords are all pretty similar so if you've seen one then etc.....
Does the cord retract?
If it's a broken spring then the pull cord would not retract.
If it is retracting then it's probably dirt, grass clipping interfering with the spring loaded locking lever.
Either way the only way to be sure is to remove the top cover and inspect it visually and clean it out and spray some lubrication on it.
You should be able to do this without taking apart the actual cord and retracting coil spring. It should come off as a unit.
Once you have inspected it if you you have any other questions please let me know.
Hope this helps.
Jun 16, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Trying to replace pull cord for kee tm22 push mower. new cord will not retract. replaced with new cord and now cord will not retract when pulled. spring came out while removing old cord but replaced in...
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Mar 27, 2010 | Garden
Pull Rope Broke... How do I replace it and still have it retract?
with the cover in your hand pull the cord out with a pair of needle nose pliers or a little screw driver and where the cord go through the case and before the wheel. pull 5 to 10 inches out and wrap the cord around the wheel turning the wheel but not winding the cord on., do 3 or 4 wraps then pull the handle to get all the cord out and let it retract. if not enough rewind just repeat with 2 wraps
Jul 22, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2 cycle Gas Engine 18" Chain Saw Logo
332 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
