Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sony kp-53hs30 rear projection TV
The colors are seperating,making for a 3-D veiwing experience.I have tried adjusting the lens,but that did not help.Is there any easy solution?Thank you,Dave
  • Sony Master
  • 8,617 Answers
Replace the two convergence ICs and a couple 3.5 amp pico fuses. You need STK 392-560 convergence ICs. You can get replacment ICs and pico fuses at the following link. with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Aug 15, 2008
Replaced convergence ic's and picture is good but still no blue color to adjust in the convergence mode. the blue bulb is lit in back.
You may have pressed a wrong button when in service mode---it allows among other things to turn individual colors off like Blue--to make it easy to adjust red to green first.
Also take a look with set on into the Blue lens to make sure you have a image and it does not look like a blue flood light.
a last note: if you tampered with the lens (they have a wing nut on side that allows them to be turned you may have on the blue turned the lens so far there is no focus---for that lens--Did you?
May 30, 2012 | Samsung HCN4727W 47" Rear Projection...
Everything is yellow! It was working fine a week ago but when I went to do a presentation yestereday everything is yellow??? I tried adjusting the colors and I tried a second computer but yellow
hello,
what this indicate from the color display on the system mean that the display sensor (lens)in getting weak it need servicing or a replacement, to to this servicing you will have to unscrew (open) from the stroll then clean up the lens with little spirit solution on the surface with care allow the solution to dry up it self then reset the programming on it please while doing this you will have to be very careful with the wire connection around ,but if this fail then you will have to get a replacement on it
This are recommended fix is to replace the lens. You can generally find replacement parts at these websites:
www.projector.com
letsgodigital.org
comforu.com
technabob.com
techshout.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing a lens is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own
thank you and thanks for you sing fixya.
Jul 01, 2010 | InFocus X3 DLP Projector
The picture shows all 3 colors seperate from each
Sounds like a problem in your convergence circuit. This is the circuit responsible for making sure all 3 colors align perfectly so that you don't see what you are seeing now. If you have tried adjusting it and that did not work then you will need to have the convergence circuit repaired.
May 24, 2010 | RCA R52WM24 52" HDTV Projection Television
52'' Projection TV SONY
this is a problem with the convergence chip. you can try to adjust the convergence in the menu settings of the t.v.
pin cushioning will correct the curves, convergence fixes color seperation.
write the number down before changing them, in case you make it worse.
Nov 11, 2009 | Sony Televison & Video
Jvc av65wp55 out of focus
When you say you changed the focus block, did you adjust each color individually ? Most projection sets are adjusted by covering 2 lens and focusing each one seperately. Try this , it has always worked for me
Sep 04, 2009 | Hitachi 46F510 46" Projection HDTV
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Veiw finder is blurred wen i look through it closeley,but far away its fine pls help
Garth
Under the veiwfinders eye peice is a small switch! look in veiw finder and adjust switch to focus and it will clear up for you!
Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | Sony CCD-TRV238E Camcorder
Adjusting the color bulbs
its not the bulbs that u adjust. its the lenses ussually theres an access panel on the back when u open that up you should see three or four lenses. if you have somebody looking at the screen while u adjust it u might be able to get it closer but to have it dead on it might be best to call a proffessional. but trying it yourself first couldnt hurt anything,
Dec 04, 2008 | Televison & Video
Games problems
try to use a low version of a driver or download this detonator. it will operate only on some features of your video card it wont push the video card to the limit so that you wont experience any mixing color while playing in warcraft. by the way just adjust the configuration of your warcraft in video so that you will enjoy your game with no hassle. hope that helps!
CHARCOIS
Jul 25, 2008 | XFX GeForce FX 5200, Graphic Card
Color problems
First adjust the contrast level 25 percent.Now see there is any improvement. If the performance is well there is a problem in video section. May be capacitor leakage like 180v supply filter, and coupling capacitor in video section.
Aug 13, 2006 | Philips 36PT71B 36" TV
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
158 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
