Question about Pentax *ist D Digital Camera
My Pentax wont keep its date or time. I set it, turn it off and on again and it has reset to default date
    Problem Solver:
  • 13 Answers
Http://www.pentaximaging.com/files/manual/istD_IB.pdf
Most likely the batteries need to be replaced, or they are being jostled and losing connection with the resistors in the battery bay.
Posted on May 21, 2011
Wont keep the time and date current after power off
there is an internal battery in side the unit and it needs replacing it keeps all information, phone programming and operational up to date and time.
Sep 17, 2015 | Eclipse Fit Clip Plus 8GB* MP3 Player
Pentax k2000 won't save time and date
In most modern cameras is a little rechargeable battery, that keeps the clock ticking. If your camera was a long time without power, perhaps this battery has died. I would buy a new set NiMH rechargeable or recyclo batteries, because they have a bit less capacity, but can hold power for as long as a year. Then charge them and leave the rechargeable batteries in your camera. Keep your fingers crossed, perhaps the little clock battery will be revived?
Feb 15, 2014 | Pentax Cameras
After battery change on my 2001 avalon the time/date reset to default even I set the time/date correctly then turn off the ignition and turn back on again then the time/date reset to default again .
If some connections were changed then the ALWAYS ON +12 volt to the clock circuit back up is not powered all the time . check if while the battery was changed if there was any link that was disconnected that is the continuous supply to the clock.
Jul 02, 2011 | 2001 Toyota Avalon
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
Bios date is not being saved
it has to be the battery contacts, the motherboard is loosing contact with the battery which is why it keeps resetting itself
Jul 06, 2010 | Computers & Internet
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
  4. Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
Camera optio e40 pentax shows the battery life as depleted even tho they are new batteries I have tried any new AA batteries 1.5 then I tried rechargagles at 1.2 for digital cameras.
this is not malfunction.
According to its manual, just turn it off ,wait for one minute and
turn it on again. It'll reset th camera. You need to reset the date/time.
Dec 25, 2009 | Pentax Optio E40 Digital Camera
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
Jun 21, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Pentax Optio A30
If you set the date during Green mode is on, then it will be reset. Turn the Green mode off first, then set the date.
Oct 07, 2008 | Pentax Optio A30 Digital Camera
Pentax *ist D Digital Camera Logo
80 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
