Yes i will... continue doing the good work.. and take care always..
    Brigadier General:
  • 10,406 Answers
Thank you.
Posted on Dec 03, 2009
SOURCE:
The circuit board where the battery plugs in not making a good connection and gps wont come, the wiring from car lighter to gps is good , canyou solder wiring to power circuit board.
Hi, yes it's possible you need a soldering iron and 60/40 rosin core solder, remember that soldering iron can make serious burns so be careful, and always work with the device disconnected from any power source.
Nov 13, 2015 | Magellan Car Charger Vehicle Power Adapter...
If I have weak knees, is jumping rope a good exercise for me?
Yes it is! Jump rope is considered a low level plyometric exercise, a low impact exercise. High level plyometric exercises are bad for weak knees. You should always be careful though. Try to land on the balls of your feet and not the heels and make sure to keep your knees lax. It is always a good idea to consult with your athlete/physiotherapist/trainer.
Jan 03, 2013 | Exercise & Fitness
I just bought a used ktm 65 sx and the previous owner said he always used mobil 1 0w-30 in engine. is this the same mobil 1 oil 0w-30 i see on local auto part stores?
Hi, Yes, indeedy. If it worked for the last owner then please continue. As you bike ages you can go to a synthetic oil. Its more expensive but worth it. Congrats on the new bike and be careful too.
Jul 30, 2011 | 2009 KTM 65 SX
Can plug boots go bad
Yes they can, I see it pretty often. Unscrew it from the wire and test it for continuity with a multimeter. Always do this before you test the coil.And if you test the coil, test it w/out the cap on. Good luck!
Jun 14, 2011 | Suzuki GSX-R 750 K Motorcycles
This recorder box every so often without reason shuts down. The only way I can get it going is by unplugging it and plugging back in. Any solutions please?
U know basic electronic and have all the tools also can do basic soldering work?Yes,take the unit aparts.Check all the components parts that call capacitors on the circuit board carefully it is dying and leaking.These capacitors parts are alway bulges up or puffing onto it tops.By replacing all these dying capacitors components,than the unit will continue contantly provided correct voltages current to the unit,than it will not shutdown again.
Jun 14, 2011 | Sharp TUTV322H
Hi My Samsung refrigerator is working fine, but water dispenser is not working. Water is leaking continuously. I guess the lever is broken or not working. Can I open the unit and repair it myself?
Yes you can, it's yours but if still on warranty period, do not do it, warranty will void.
If you can do then do it, be careful with parts you disassemble. If you can't call a service technician to do that.
I hope I give you some idea, good luck!
Jun 11, 2011 | Samsung RS2534 Side by Side Refrigerator
My whirlpool ultimate care heavy duty super capacity dryer is not heating at all ,I tested the heating element for continuity , & have none , so this means the heating element is bad?
yes if you do not have continuity that meens the element is bad. just to be sure you may want to double check meter to make sure it is working properly, or check element for visual damage
May 12, 2011 | Whirlpool Dryers
My Whirlpool washer (Ultimate Care II) stops at
This is probally the lid switch. You can check this by checking for continuity. You should have none with switch open and some continuity when switch is closed if yours has continuity when opened you will need to replace. There is a video at www.appliancehelponline.com/servicemanual.html that can walk you thru the replacement.
Mar 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Open Questions:
Computers & Internet Logo
13 people viewed this question
Ekse
Alun Cox
