Question about Intermatic T40404R - Pool-Spa Control Panel - T104M Mechanisms - Steel
I have a Intermatic T40404R and need a replacement timer. I have examined the timers in my unit and find no part numbers. Other sites offer a T101M as well as a T104M. Which is the correct timer for my Intermatic T40404R? Thanks...
Thank you for including model number.
Intermatic catelog shows that T40404R is shipped with two T104M timer mechanisms.
However the mechanisms can be changed out for either T101M or T104M, and these timers can be wired many different ways so there is not 100% certainty unless you know or test voltages.
Here's the general difference
T101M is 120 Volt with 120Volt clock motor
T104M is 240 Volt with 240Volt clock motor
You can buy $20 clock motor and $3 trippers and fix the timer mechanism instead of replacing it.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Add a comment to this thread any time as you're working on project and I will get message.
Other useful links:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 21, 2011
I have a t40404r. one timer has been unused. i attempted to wire it up this week. the manuel switch works when i flip it to on but the timer/wheel/motor will not work. i have two 110 wires attached to...
If it was me the first thing I would do is to verify that you have the proper voltage to the timer that you are hooking up. I would also take the timer that is working and replace it with the one that isn't and see what happens. This may tell you that the timer is bad. I would put the working timer in the place you are trying to put your new one. This can tell you if your power supply is right. Hope this helps. Thank you
May 16, 2011 | Intermatic 125 Amp Control Center T40404R...
I would like to know how to wire my timer to my breaker box and pool pump? it a t101m 120v.. my pump has a white and black wire and some to my timer to my box
Wiring diagrams for T-101 appear on following link:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Hot wire goes to terminal 1
Neutral to terminal A
Black wire to pump goes to terminal 2
White wire to pump goes to terminal A along with Neutral wire.
Electricians don't guess, they test.
So lets test wires for sure:
Separate wires.
Use ordinary 2-wire tester from hardware store.
Tape tester leads to wood sticks so hands are away from power.
Do not touch anything metal, stand on dry boards.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. Hot wire connects to terminal 1.
Hot wire is identified.
Test Hot wire to all other wires in box, except bare ground wire.
Tester lights up on Neutral wire. Neutral wire connects to terminal A.
Your other two wires go to Load.
Connect Load black to terminal 2
Connect Load white to terminal A
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 08, 2011 | RTO Intermatic T101M Timer Mechanism Only...
1 year old t101m timer stopped working. The manual on/off works but mechanical clock doesn't. Is there an easy fix or should I just repalce?
T101 dial is not working so the 125V clock motor needs to be replaced:
Grainger sells 125V T100 series clock motor:
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Timer mechanism releases from box with metal spring located inside top of box.
Clock motor is attached with 2 star screws.
Notice clock motor has plastic gears, but timer has metal gears.
Metal gears on timer mechanism last for many years.
Notice also that clock motor wires connect to terminals A and 1.
After installing new motor, tighten screws very tight against copper wire.
Also take advantage of fixya phone service.
Jan 05, 2011 | RTO Intermatic T101M Timer Mechanism Only...
I HAVE AN iNTERMATIC t100m TIMER it appears to have two "off" tripper levers but no "on" tripper lever attached to the clock face dial by a set screw . Do I need an "on "...
Yes, the T101M 120Volt pool timer requires both ON and OFF trippers:
Grainger sells T100 series on-off trippers:
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Amazon sells T100 trippers
http://www.amazon.com/dp/B003YO2C5U/?tag=picc-20
Grainger sells the T100 125V clock motor
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T-101 120Volt timer
How Intermatic dial timer clock works.
Clock motor rotates dial.
Intermatic clock motor, located on back of mechanism, are replaceable
Trippers located on outer edge of dial push on-off lever
ON tripper pushes lever one direction
OFF tripper pushes lever opposite direction.
Lever pushes electrical contacts together and pulls contacts apart.
When lever moves, manual override also clicks back and forth with audible click.
To replace timer, replacement snaps into box without needing to changing box.
Dec 10, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
The dial on the intermatic water heater timer is not rotating on it's own and is easy to turn in either direction-without pulling it out and setting the time. The unit is only 1 year old..Can I replace the...
You can replace clock motor on many Intermatic timers:
Snap mechanism loose using metal spring top inside box.
Tip mechanism out and get clock motor number off motor.
Google search specific clock motor number.
Aplus sells many clock motor:
http://www.aplussupply.com/intermatic/timermotors.htm
Electric supply online sells clock motors
http://www.electricsupplyonline.com/prod/intermatic-motors.php
Grainger carries inexpensive clock motors for T101, T103, T104 timers.
T101 and T103 use 125v motor
T104 uses 240v motor
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
Dec 01, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I get lights when I turn the switch to on but as the timer advances, it doesn't trip and turn the timer on
You posted under Intermatic T101 timer.
Add a comment if timer is different.
1) If this is new timer installation, it sounds like black wires on terminals 1 and 2 are reversed.
Other cause could be the ON-OFF trippers not positioned on timer dial
2) If this is old timer that worked before, then tripper pins could be worn down.
Buy new trippers for T101 at Grainger
Nov 17, 2010 | RTO Intermatic T101M Timer Mechanism Only...
I have a w100 tork timer and i would like to know how to repair it and how to position the time pointer.
How to position time pointer
Rotate disk counterclockwise until current time lines up with silver pointer
Place trippers on outer edge of dial > trippers are reversible so one side of tripper in ON > flip tripper over and it is OFF.
Disk rotates with passing time, trippers click lever ON and OFF at set times
How to repair W100:
If dial is not rotating, then clock motor is bad >> W100 uses 120V clock > check markings on clock. Internet shows Tork T101M and T201M clock motors, but unclear if either clock matches W100 timer.
If dial rotates but trippers do not turn Load on-off then buy P-69 trippers
If manual override turns Loan on-off then electric circuit is working
If manual override does not operate Load, then check electric circuit or Load (light bulbs burned out)
If manual override is sluggish or stuck, and doesn't click crisp and clean, then timer is worn out or needs to be cleaned.
Product Manual:
http://waterheatertimer.org/Tork-timers-and-manuals.html#W-series
Link above shows manuals
Manual for W100 does not show specific clock-motor model
To buy parts or another timer
P-69 trippers available on web
Tork T101M and T201M clock motors available on web but unclear if they match W100
http://www.weisd.com/store2/tork/torktimer1.php
Page above sell W-series time dial part #70159 for 72$.
Page does not include photo, so unclear if dial includes clock-motor, or if voltage is 120V
Tork accessories pdf shows part #70159 as dial for W, with no other information
Same seller shows new W100 sells for $148.
Replace Tork with Intermatic, buy T7401B
Website sells T7401B for $114
T7401B is 120V timer and has 120V clock motor
http://www.1000bulbs.com/product/3377/ELEC-T7401B.html
Manual for T7401B
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7401b%20-%20english.ashx
Nov 16, 2010 | TORK Hardware & Accessories
Do you offer in home light timer programming in Alexandria Virginia?
Fixya answers questions for people.
We do not offer in-home service.
If you have a problem with a timer, add a comment with the model number and the specific problem.
Nov 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic T40404R - Pool-Spa Control Panel -  T104M Mechanisms - Steel Logo
199 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
