Question about Karcher K3.68MR Electric Pressure Washer
My karcher k365 leaks water from underneath body,can you help?
3 Suggested Answers
  • 32 Answers
SOURCE: hello i have a karcher b402 i have had it for a
hi, it sounds like the seals in the pump have gone,
you can repair this your self with some seals, www.karcher.com then click on europe,then international the screen will change.
go to services the spare parts, in put your model.
it will help if you can also find the 8 digit number starting with a 1.something something something dash something something something dot nort.
or ring me on 01729825656
Posted on Jul 04, 2009
  • 68 Answers
SOURCE: Hi My karcher k3.65 jubilee is leaking water when
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Posted on Jun 11, 2010
Why is smoke coming from karcher pressure washer and leaking from underneath
You need to make sure you have water flowing through the machine before you turn it on. The pump could be bad in it and or the seal make have broken which is causing the Ayer o leak out.
Feb 04, 2015 | Karcher Garden
Leaking water out of the pump body and there is water in the housing that holds the bearing so the oil is contaminated.
Doesn't sound good. If you didn't add antifreeze (depending on climate) in the fall, then water that is in the pump will freeze and pump will need replaced. In any case you have to take the pump off. You might possibly get away with replacing shaft seal and a new gasket on the pump body. let us know
Sep 22, 2010 | Karcher 2500 PSI Pressure Washer
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
No pressure
more than likely it has frozen , if you did not disconnect the hose and drain residual water from unit
Apr 21, 2010 | Karcher PSI Electric Pressure Washer
Just started using my kb4040 and water i s leaking
Sounds like the water seals are bad. For Karcher parts go here: LINK
Jan 18, 2010 | Karcher 1750 psi Electric Pressure Washer
Hello i have a karcher b402 i have had it for a few years it is stating to leak water from underneath allthough not a problem what can i do with this please edwin read
Jun 29, 2009 | Garden
My karcher G2000QT WORKS AT HIGH PRESURE FOR A COUPLE OF SECONDS AND THEN STOPS THEN A COUPLE OF SECONDS LATER WILL START AGAIN WHATS GOING ON?
are you making the machine **** for water, if so you have got a air leak on the suction hose.
try force feeding with water by connecting your hose to the mains water hose and see if you can see a water leak.
could be starved of water also,chack the filter
Jun 28, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Jun 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Jul 29, 2007 | Karcher 2500 PSI Pressure Washer
Karcher K3.68MR Electric Pressure Washer Logo
270 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
