Question about Car Audio & Video
The delphi receiver is stuck on updating channels message, It will play CD's and will turn on and off as well as volume adjust and external audio option. Any ideas?
SOURCE: Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Posted on Jan 20, 2008
SOURCE: Faceplate
if the random button is stuck its the caue of your problem because if you hold one button pressed the others wont work.
on the back of the face plate there are 4 little screws take them out and see what is holding that button stuck or pull it out if you can ...
Posted on Jul 30, 2008
CRTN
  • 716 Answers
SOURCE: How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Posted on Jan 05, 2009
  • 10 Answers
SOURCE: sound issue on LG 42LG50
make sure the dish network menu settings in setup under audio are on high. Some tv's require it to be off. Try both and see what works. Also the delay is caused by digital conversion. new stereos have settings for this delay and they have delay boxes for sale online. You could try to change your delay settings on your stereo surround to help. I had to do this.
Posted on Jan 08, 2009
elecgooroo
  • 57 Answers
SOURCE: AVN5500 - Display stuck at "Updating" when using Sirius.
yes it is the sirius unit I was told to drop all power while system is on disconect the battery while ignition is on then turn back on and wait ten min for update to complete if that does not work call sirius to have them send the update mabe they can tell you when its complete hope this helps..
Posted on Jan 10, 2009
My radio just recently goes up to 119 and several of the channels i listen too come up as updating....and won't play.
Give XM a call, since they merged the channel lineup has changed. Have them push a new activation signal to the unit, which should unlock the rest of the channels. However, the roady XT isn't exactly known for its reliability, so the receiver itself might be dead.
Sep 12, 2011 | Delphi Roady XT XM Radio Receiver
Can't get sound to come from speakers with tv only the radio
You didn't give the brand and model of your TV, and I can't try to find a manual and see what kind of AV connections it has available. So here's some general information.
Many TV sets only have input jacks for external sources like DVD players or cable boxes. When you select an external source, or use the set's internal tuner for TV programming, the video and audio play through the TV. The trouble is that if the set has no audio output jacks, there's no way to get a sound signal out. The TV accepts only inputs
When the TV is part of a home theater system, most people use it just as a video monitor. All AV sources connect to the receiver, and audio is sent from there to the speakers. A video output from the receiver goes to the TV so you can see the picture, and the TV's speakers aren't used. If you have a cable box, FiOS set-top box or satellite receiver for your TV channels, they connect to the receiver too, since they're just another external source.
This doesn't work if you rely on the TV's internal tuner for TV channels, though. This might be the case, for instance, if you have a cable system where a converter box isn't required and your cable connects right to the TV. When you're watching regular TV, then, the sound comes through the set's internal speakers. If there's no audio output available on your TV, that's your only option.
As I said earlier, many TV's have only audio inputs. But some have audio output jacks as well, so the sound has a way out. If yours does, you can connect them to one of the inputs on the home theater receiver. Then when you select that input you'll get the TV sound through the speakers connected to the receiver. Depending on the design of the TV, you may need to leave the TV volume turned up. Some sets have outputs that are follow the TV's volume setting. On others, the output is an independent fixed level. Then you can turn the TV volume down and use just the receiver's speakers if you want.
Check the connections available on your TV and look for a set of "audio out" jacks. Your TV's owner's manual should have a section explaining how to connect it in different ways. If you need a copy, most manufacturers have manuals for download on their website.
Good luck with your sound, and thanks for using Fixya!
Jun 17, 2011 | RCA Audio Players & Recorders
I have hk3385 receiver and Ipod Touch 4G. I have the cable to connect them. Where do I hook the cable on the receiver (or do I?) and which buttons will play the Ipod music. No video, just music
The manual suggests that you use "A / V 3" (audio / video input 3) for your iPad / iPod audio input. These are the RED and WHITE jacks on the front lower right hand side of the receiver. The YELLOW jack is for composite VIDEO, and need not be connected for "audio only" programs.
Turn the volume on the iPod / iPad to MINIMUM (assuming the receiver volume is at a "normal" setting for the radio, CD, etc.). Connect the cable between the iPod / iPad and the A / V 3 RED and WHITE audio jacks. Select A / V Input 3 on the receiver. Find a song you want to listen to and select PLAY in the iPod / iPad. Slowly adjust the volume on the iPod / iPad up to a comfortable level. If there is distorted sound, adjust he receiver and iPod / iPad volumes up and down as needed. Generally, neither should be set very low or very high.
You can download the owners manual here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 20, 2011 | Harman Multimedia HK 3385 2 Channels...
My xm radio is all lit up it shows all of the information but you can't change channels get into the menu or any other functions it is like it is locked up. any suggestions
Hold down "power" and "volume up" at the same time to do a reset. You need a 'firmware update' from the Delphi website. Also, you can call Delphi for help too.
May 07, 2010 | Delphi SKYFi3 XM Radio Receiver
MY Sony CDX-R3000 will only play CD's. It will not allow me to adjust volume, skip songs, or play the radio
Try and reset it . disconnect battery under the hood for like 5 min and see what happens ..I had that radio and sometimes its just tempermental . take cd out and try it ? Sre any buttons stuck ? If that doesnt work then hopefully u like your cds at the volume they are at . Good luck
Oct 07, 2009 | Sony CDX-R3000 CD Player
My delphi roady plays through cassette adaptor. Volume is very low even when audio level is moved all the way up. ???
You need to cycle back through after puttung the cassette in. Mine did that (before the cassette feature stopped working altogether) and I would press my "source" button so it would go from the cassette to the radio, then CD and back to the cassette - the sound would be back to normal again.
Oct 06, 2009 | Delphi Roady XT XM Radio Receiver
The factory xm volume to low in 2006 corvette
Separate 'plug and play' XM radios, like the one pictured above, have a "MENU" setup, and you can adjust the "Audio Level" in that menu setting. See if you can access an XM menu. You can also ask your question over at XM411.com or XMfan.com; both are 'fan' websites.
Good luck - nice car too!
Aug 05, 2009 | Delphi SKYFi2 SA10126 XM Radio Receiver
Sony CDX M730 won't operate manually, remote doesn't work either
my sony wnt flip down so i can change cds its stuck
Feb 16, 2009 | Sony CDX-M730 CD Player
My delphi xm is frozen
My radio was stuck on "scanning media" and the regular reset (volume up and Mode) did not work.
Nothing that I did, fixed it...
I called Delphi and they said...
(1) Put radio in it's cradle, press Volume UP/Mode buttons for 3 seconds until it resets.
(2)Then when the "scanning media" message appears press up arrow, down arrow, up arrow.
My delphi screen unlocked. I LOST everything that I had recorded, but that was fine with me.
I had to update the firmware and everything is working fine.
Losing all my recorded songs was much better than having to send in my radio!
Hopefully this will work for you!
Delphi was extremely helpful and very nice so don't be afraid to call them if this doesn't work!
Jul 10, 2008 | Delphi SKYFi3 XM Radio Receiver
Faceplate
Sep 03, 2007 | Panasonic CQ-C5310U CD Player
Car Audio & Video Logo
118 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
