Pilot light will lite and seems to work fine, when lit the first time, but gose out when it comes time reheat the water.
    Problem Solver:
  • 19 Answers
This sounds like an issue with your water heater and not your air conditioner. If the pilot is going out, your thermocouple is most likely broken. If you travel to the nearest plumbing supply store, they can give you a new one and instruct you on how to instal it.
Posted on May 21, 2011
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Jandy lite 2 pilot wont light
dirty pilot tubing or weak pilot generator
Dec 04, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
I want to light the pilot but do not know how what is the red button for and do you turn on the gas to light pilot?
nope - don't turn on gas at the Range's front control panel to light the pilot lite.
but you do need to turn on the gas to the kitchen range at the plumbers black pipe valve to the Range.
To light the pilot light:
(1) depress the red button (that feeds the gas to the pilot light orifice)
(2) using lighter/match/lit rolled-up newspaper, etc, light the tiny amount of gas coming from orifice
(3) continue to hold dow red button for 1 or 1.5 minutes (this allows heat to bend the bi-metal contact)
(4) after 1-1.5 minutes with a lit pilot light, release the red button - the pilot should remain lit
(5) you're done lighting the pilot lite - turn on the oven (or broiler).
Dec 27, 2010 | Kitchen Ranges
Pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Nov 08, 2009 | Procom ML300TBA Heater
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
What's up with My Bosch Hot water heater??
it sounds like a thermocoupler
its located inside the unit next to the pilot flame and should be screwed in next to the pilot button at the other end
May 28, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot light out?
It fixed itself and worked fine the next day.
Thanks.
May 26, 2008 | Amana ARGS7650SS Gas Kitchen Range
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
