Question about Motorola Mobility H350 Wireless Headset
Bluetooth got wet in rain
I was trying to get from the car to the house and it got wet, is there any hope??? It won't come on.
  • m0wm0w Mar 28, 2009
    I accidentally left my motorola blutooth in my pocket and put it in the washer and i was wondering if it will ever work again. Please let me know!
My 2004 Alero has a problem when it rains. It won't start after it was rained and it seems to me that something is getting wet under the hood and causing this that I have to let it sit after it rains,...
I doubt anything is getting wet, but you could be right on a bad connection. You could have enough humidity in the air after a rain to cause a weak connection to fail completely. It could also be a faulty relay.
Someone would need to figure out if you are lacking spark to the plugs or fuel pressure when it fails to start, then track down why.
Jul 12, 2013 | Cars & Trucks
Car cranks but won't Start
It sounds like your alternator mat have gotten wet. there is usually some sort of cover under the alt. I would get that and the battery tested. They can be tested while still on the car. If it won`t start you would have to get them pulled and checked. Usually free of charge.
Nov 12, 2012 | 2001 Audi TT
My car won't start after I drove in the rain,what could be wrong? Could it be something electrical like fuses or something that got wet?
possibley try spraying the ignition leeds with some wd40 or equivelent or it could be the imobilezer which is worked from the drivers side door if none of these can you here it prime befor the engine starts can you here the fuel pump there is a relay thats in the boot for the pump check this not normally bad starters prety bomb proof i have a 1994 c180 18 years not had a bit problem with it i would check the few points i have listed above before spending any money hope this helps ivan
Oct 24, 2012 | 2003 Mercedes-Benz S500
Ceiling getting wet
Is this a house or car??
Oct 14, 2012 | Dodge Caravan Cars & Trucks
Driver was left out in the rain, got wet and now won't work
If you tried it straight after, it may now be broken. The general treatment is to take out any battery, and place it in a warm dry place for a day or two to eliminate any moisture. The internals of any drill will not usually be damage if you do this.
The same is true to some extent of mobile phones, key remotes etc.
Mar 25, 2012 | Makita Drills
So i was walking outside and then it suddenly started raining and i tried to cover my nokia n97 but it got a bit of rain on it. I ran back to my house with my phone in my hand. It worked until the battery...
hi have you tried other battery? if not, kindly replaced it. if yes, pls bring it to service technician to open it i guest inside board is wet due to rain, they will used hot air blower to dry it. thanks
May 09, 2011 | Nokia N97 Cell Phone
Left back floor was soaked after driving in heavy rain.
IS THIS CAR FOUR DOOR OR TWO NEE D TO NO SO I CAN TELL YOU WITCH WAY TO GO ANY WAY I WOULD GET A HOUSE OUT BUT SOME ONE IN CAR IN BACK AREA AND SEE IF THEY CAN FIND LEAK IT MAY BE AROUND WINDOW SEAL HOPE THIS HELPS SEEN THE SEEM IN WHEEL WELL DO THIS BUT MAY BE BACK WINDOW SEAL IS TRUNCK WET TOO .
Aug 12, 2009 | 2002 Toyota Camry
Distrutor problems, every time it rains or gets
use dielectric grease from arts house!!!! :)
Jul 06, 2009 | GMC Sierra 1500 Cars & Trucks
Nokia 5200 bluetooth is not working
well you need to take the phone and have it fuly service and also reflash the software on the phone.
Aug 07, 2008 | Nokia 5200 Cellular Phone
Motorola Mobility H350 Wireless Headset Logo
825 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
