Question about Toshiba Satellite M45-S355 Notebook
How do you turn off the touch pad? - Toshiba Satellite M45-S355 Notebook
  • 731 Answers
Click START, ALL PROGRAMS, TOSHIBA ASSIST, then click the MOUSE icon.
Setting are there
Posted on May 21, 2011
Testimonial: "Thanks a lot. It was a big help."
How do I fix my acer aspire touch pad?
some touch pads have a tap to turn off, and a double tap to turn back on... also check you F keys.
Jun 03, 2014 | Acer Aspire Computers & Internet
Touch pad sony viao vpceb3j1e not working
Hey there. Often times this is a problem caused by accidentally turning it off. Look for a button on your keyboard or near the touch pad to turn the touch pad on/off. If you're using windows 7 and possible below, you won't need drivers to get the touch pad to work normally.
Jul 26, 2011 | Computers & Internet
My touch pad is not working. There is an orange light on it.
I am really sorry to hear that your touch pad is not working. You mentioned that you see an orange light on it, where did you see it? is it on the top of your touch pad? if it's just on the top of your touch pad, all you have to do is just press the button right beside the orange light. Because the touch pad is being disable indicating the orange light, when you press the button you will see a blue light indicating that you enable the touch pad.
Thanks.
Jul 24, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
The touch pad stopped working and the a small light on the touch pad turned on.
Just press the button near the touch pad or press fn + the key with a picture of a touch pad on it.
Jul 15, 2011 | Computers & Internet
My toshiba satellite A355D touch pad is not working. my husband told me that probably my kid turned it off. if that is the case... how can i turn it on?
Sounds like your touch pad may need to be replaced.You can't really turn off the touch pad.Even if your child managed to uninstall the touch pad it would load back the drivers at next startup.Chances are the touch pad will have to be replaced.Its possible the touch pad may be disconnected from the motherboard but not very likely though.
Aug 24, 2010 | Computers & Internet
Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Jul 10, 2010 | Acer Aspire One PC Notebook
I am receiving the same error message on the display window
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Function key shorted or stuck :
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 12, 2009 | Maytag MER6769 Gemini Electric Kitchen...
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Touchpad
This may be a simple driver glitch. Try uninstalling the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers. The touch pad either works or it doesn't, there's no in between, so if this doesn't work, then I'm afraid you'll have to replace the touch pad.
Jul 17, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite M45-S355 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
