Question about Microwave Ovens
Model nn-a514abbpq Panasonic inverter slimline combi microwave Just shut down-no light nothing. checked the plug fuse Is there another fuse anywhere?
MicrowaveSvc
  • 9047 Answers
SOURCE: broken door catch, possible spring,
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: I desparatly need instruction for the NN-A554W
Apparently that's a UK model.
You can visit Panasonic.net, select your country, then follow the support links to find the manual download area.
If yours in not there, look for spares or service centers to order one.
Posted on Mar 06, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: i have a panasonic slimline combi NN A554W which
, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Posted on Oct 06, 2009
jsrock516
  • 5911 Answers
SOURCE: our neighbour is misson the user manual for her
Go to managemylife.com and type in your MODEL NUMBER under the "Manuals" link. The website has an extensive list of owner's and installation manuals for many brand names. The manuals are listed in .pdf (Adobe) format and can be downloaded or printed for FREE. If you need further assistance, please post back with your MODEL NUMBER and let me know.
Posted on Jun 07, 2010
  • 2509 Answers
SOURCE: Panasonic manual for NN-A873SBBPQ combie microwave
go here click on the rows of stars to rate the oven and you can the download the manual. http://safemanuals.com/314159.php?k=2a358ce2c944a173d7f6156b61640058&ID=190866&q=PANASONIC%20NN-A873SBBPQ
regards
Posted on Jan 27, 2011
Panasonic microwave combi oven model nn a772 sbbpq. I set the microwave for 12 minutes but forgot to put the meal in. It now works for a few seconds then stops. Any help would be appreciated
A thermal cutout on many ovens is black with two terminals. It's usually held in place by a bracket and one or two screws. Many ovens now use a thermistor instead of a cutout on the magnetron.
Based on the symptoms you describe, it seems unlikely either would be the cause of the problem. If a microwave is run empty, the magnetron will draw excessive current. The excessive current can take out the magnetron, high voltage rectifier, high voltage capacitor, fuse, or a few other components. If this is an inverter oven, check for a fault code of "H98" or something similar. That would indicate a problem with the inverter board, or something else in the high voltage circuit.
Feb 09, 2017 | Panasonic Microwave Ovens
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
I have been given a Panasonic combi inverter microwave/oven. There are no user instructions can you help me to find a manual?
here is the link to the instruction manual of your device from panasonic:--
click the link directly:--
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/model.NN-H275BF
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 06, 2009 | Panasonic Microwave Ovens
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
I desparatly need instruction for the NN-A554W inverter slimline combi PLEASE can you help
Mar 05, 2009 | Panasonic NN-A811A Convection/Microwave...
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
