Question about Kenmore Sewing Machines
Bobbin thread and top thread tangle and machine stops after two or three stitches
  • 776 Answers
Option 1)
The bobbin may not be installed exactly in the right way (a little askew).
Option 2)
The Tension needs to be adjusted
Option 3)
Your needle is bent or dull
Option 4)
One thread does not work well with the other. The threads must be able to slide and tighten, too much friction for one thread can cause tangles.
Let me know if any of those are pointing us in the right direction. i can give more advise as needed. Also, check youtube.com to learn how to set the tension on your machine (most are similar, the knob is just in a different place on each machine).
Try:
http://www.youtube.com/watch?v=es24cH-uRQU
The tension contolls the feed rate for the bottom (bobbin thread). The top thread is mostly controlled by the stitch length knob. Play with both a bit. Bottom should come out when pulled gently but give some resistance. Good luck.
Posted on May 22, 2011
  • Mark T
    Mark T May 22, 2011
    Also, the upper and lower threads should be pulled to the back of the machine before you put your fabric under the foot. If they are tangled to start with, they will immedately get tangled when you start the machine. Keep them straight.
    Good luck=
    -mark
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Bobbin does not sew: the upper thread gets tangles underneath but the bobbin thread is not involved
bird nesting indicates that the needle thread tension is not tight enough
pull the thread out as if threading the needle and the tension is close when there is resistance to pulling the thread
Oct 11, 2017 | Brother Sewing Machines
Tangled thread on wrong side. The thread on the
I'm guessing it is because the tension is not just right, the bobbin might not be the right size, the thread type top and Botton might not be the same, or you just might need put in a new needle the right size.
Aug 09, 2017 | Brother CS-6000
Worked great until the needle broke and now the bobbin thread bunches up
Hello
Clean out the bobbin area if there are any thread tangles there.
If the bobbin does not fit snugly into the bobbin case, then get new bobbins. You need class A or 15 and they do not cost very much. Make sure they are plastic and not metal.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
There should be a tension setting for your bobbin thread, as well as your top thread. It sounds to me like your bobbin tension setting is not in sync with your top thread.
most common solution to this is to remove the top thread completely from machine and re thread it with the presser foot UP not down. This will allow the top thread to engage properly in the top tension disc
Aug 10, 2011 | Brother LS-2125 Mechanical Sewing Machine
My machine is a designer 2 but I encounterd a problem with my stich getting all tangled. tryed to clean the bobbin case and under, stich is still tangling bad.
Be absolutely sure that the machine is threaded correctly, with the upper thread clicked into the tension discs (the presser foot MUST be raised when you thread so the tensions discs are open to receive the thread) and bobbin thread clicked into the bobbin tension slot. Change the needle - a bent or blunt needle can cause tangles. Hold onto the thread tails for two or three stitches when you first start sewing to avoid them being drawn down under the fabric and making a mess.
Dec 19, 2010 | Husqvarna Designer I
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Amatur Sewer?threads tangled below
Stop sewing! You need to adjust your tension. Your book will explain exactly how to do this. If you can't find your book, try setting the tensions to the same number. If your tension adjustments have a mark at a certain number, use that setting for most materials. If not, try setting it to about 3.
To test your settings, thread your bobbin with a different color, then do a test stitch. Check the top and bottom stitches for a spot of the other color thread showing through. If the bobbin thread shows in the top, raise the bobbin tension setting a bit and try it again.
Hope this FixesYa!
Aug 11, 2008 | Singer 3116 Simple
Bobbin
Hi Sally,
Don't forget to change your needle too. It may not look bent, but it probably is.
Nov 06, 2006 | Rex RX-1804
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
