Question about Kitchen Ranges
How to hook up propane tank - Kitchen Ranges
    Brigadier General:
  • 3,301 Answers
The older tanks have a inside thread that screws into the fitting at the top, the newer ones, have outside threads,, Just unscrew either and screw back in the new canister
Posted on May 21, 2011
I hooked a thermador cooktop to a BBQ propane tank. The flames are large for a second and make a puff sound and the shrink to nothing. All 5 burners do the same.
It does sound like a faulty regulator, propane operates at 2.75kpa and if the existing regulator is for natural gas it is only 1.1kpa.
If you are operating off a bulk tank the regulator on the tank may be high pressure then the secondary regulator on the appliance may be to bring it down further. See if you can get a manometer and check it all out before doing any regulator removing.
Apr 05, 2014 | Thermador Cooktops
Hooked up proane tank used once then no flame on grill. There is propane in the tank but no propane flows out of it either when hooked up to the grill or when opening the valve directly on the tank. This...
The valve on the tank has an internal valve that will not allow you to release propane into the atmosphere. It must be connected to a regulator line in order to open.
It sounds like your regulator has failed. Remove the regulator assembly, inspect it carefully for blockage or hose kinks. If there none, try replacing the regulator assembly.
Gary
Sep 24, 2011 | Weber Genesis E-310 Gas Grill
Machine will not ignite...ignitor clicks...new battery...new fuel filter...new propane tank...cleaned machine...help!
is the propane hooked up correctly with the valve turned on, and verify that there is propane inside the tank as I have purchased new tanks that were empty. Hope this helps Tim
May 15, 2011 | Garden
Gas gauge... how does it work... or is it supposed to be hooked up to the can somehow??
If it's like mine, you literally hang the propane tank on a hook. The gauge is basically a spring and as the propane is used and lightens the tank, the spring contracts.
Jul 27, 2010 | Weber Genesis E-320 Propane Grill
Low flame out put
I assume this is a propane grill. First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Feb 07, 2010 | Grilling
Can i hook two 500 gallon propane tanks together instead of purchasing a 1000 gallon tank?
yes you can but please get a propane gas certified engineer to do it , its really a job to be done by experts , the explosive power of propane is just to dangerous to mess with
Nov 10, 2009 | All-Pro Propane Garage Shop Heaters - All...
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
We moved from ohio to las vegas had the grill in moving truck. got new propane tank hooked it up not getting much propane to burners. there is hardly any flames.
Try this turn tank off make sure all knobs are in the off position check side burner if you have one disconnect tank reconnect tank make sure fitting is all the way on turn tank on and try again if this does not work you probably need new regulator and hose
Sep 02, 2009 | Grilling
Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Jul 03, 2008 | Coleman Roadtrip Grill LXE 9949-750
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
