My speakers are pluged in but there not working.. my computers saying that threres no device pluged in.
    Problem Solver:
  • 19 Answers
Troubleshoot the issue by plugging in a different set of speakers or head phones into your computer.
If the new pair of speakers/headphones works, then your other speakers are broken.
If the new pair of speakers/headphones do not work, then the problem is with your computer audio, and I would recommend updating the drivers.
Posted on May 21, 2011
Everything is pluged in correctly. And when i go to the control panel> Sounds, speech, and audio devices> sounds and audio devices> volume, it says that their pluged in and work, but i dont here...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 16, 2011 | Dell A215 Computer Speakers
We are hooking the speakers up to a new computer and we don't have the software
Threre is no software for these speakers. This is the installation guide:
http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf
Make sure you have the proper sound device activated and volume turned up. If after speaker set up, you have no sound, get into your "device manager" and click on the box next to"sound, video and game controllers"(on right) and, righy click on each device that shows in the list. You should see "disable". If you see "enable" click on that and exit. You should have a speaker icon in your taskbar, lower right of screen. Right click on that and then on "open sound mixer" and, adjust your volume.
Jun 14, 2011 | Logitech Z313
I have pluged all speakers but not sound on the front and rear to working when i play test they all working but not when i open a music from windows media player.
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Dec 11, 2010 | Logitech X-530 Computer Speakers
My speakers quit working. my computer doesn't recognise they are even pluged in. says no audio device. i was hoping to get the exact driver for lcs-2424 so i could reinstall it
if your computer came with a disk the sounds drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 25, 2010 | Labtec LCS 2424 Computer Speakers
My ipod is not detecting on my PC its saying the usb device is not recognizable
You may need to install iTunes or if you already have it installed you should try to update it to make sure it is the most recent version of itunes then try pluging the ipod in.
Mar 21, 2010 | Linkworld Electronic Co. MULTIMEDIA...
Different speakers, still says i have audio, but no sound
if you look device manager and there is not yellow sign (in speaker sign) your stal sound driver is correct. if not ok right mouse click in speaker then u can up date driver. driver of sound keeping bord cd.
2/ type on run as "control" then go on speaker and sound(diffrent computer hav different sign) and look setting and correct setting.3/ your speaker may be damage check it on other computer and c desk4/ if u not do sound setting in mute?
Jul 10, 2009 | Dell A215 Computer Speakers
Speakers not working.
The easy way to trouble shoot sound problems is to plug the speakers into another device like a portable player and see if they produce sound. If you had sound from your portable device but no sound from your speakers then your speakers have died. You can see if the computer is producing any sound by pluging your headphones from the portable into the computer and see if you have sound.
May 01, 2009 | Audio Players & Recorders
My sound not work
when you connect your speaker with pc then keep in mind that you are pluging the right cable in right place.
Mar 10, 2009 | Sys 4.1 pc. 140 Watt Speaker Computer...
New speakers are not working with the computer
try and connecting other device,and see if they work. check connections green jack on computer is audio out. they could be defective good luck.
Jul 23, 2008 | Audio Players & Recorders
I have a set of Durabrand UC280 speakers. Pluged them into my cumputer. No sound. The speakers seem to work OK. Have checked systems and all say are working correctly. Any suggestions????
Are you sure you are plugged into the speaker output on your computer? Of not try the other outputs, and also make sure the volume is turned up and not muted on your computer, check by double clicking on the speaker icon in the lower right hand corner of your screen or by going to the sound applet in Control Panel.
Have you tried these speakers on another computer or with a CD player or MP3 player? If they don't work with another device either than you know there is a problem with your speakers.
Also make sure that the speakers are plugged into a power source if they require it, most likely they do.
Jul 02, 2008 | Computers & Internet
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
