Question about Vacuums
I have a clarke bench grinder model 1002. I have a light that I would like to attach into the wiring though the grinder wiring in it's base. The light has two wires, and the grinder has a ground that is grounded to the base, a black that goes to a switch then to the motor. The white goes directly to the motor. where would I have to splice in the two wires from the light? I have a switch that I would like to put in for the light on off also.
  • 731 Answers
Attach the white wire on your lamp to the white wire on the grinder.
Attache the black wire on your lamp to the black wire on the motor side of the switch.
This will give the lamp power any time the grinder is turned on.
You can put a switch inline of the black wire to the lampp and it will allow you to turn it off when not needed
OR
You can attach the white wires together and the black ones before the switch.
If you choose this way you will need a switch as the lamp will be power all the time.
Posted on May 21, 2011
Floor brush won't turn.
if yours is a dual motor unit a microswitch in the base of the vac powers the brush roller, additionally the carbon brushes may need replacement..far cheeper than a motor.
or your belt may be stripped or streched due to string or hair binding the bearing
Aug 03, 2013 | Clarke CombiVac 12 Bagged Upright Vacuum
Clarke scrubbers
If you attach a picture of the scrubber, and give the model number, I can help. I retired from repairing these floor machines after 30 years. I like Clarke machines.
Mar 11, 2017 | Clarke Vacuums
When I go to use the attachment tools the vacuum acts as if you have sucked up a bag. It will vacuum fine, but can't use the hose and attachments. Please help! Purchased it Sept. of 2010.
Sorry to hear you're having difficulties with your Dyson cleaner. From what you've described, it sounds as though you may have a blockage somewhere in the hose or wand. However, the advice we'd recommend for resolving this would depend on which model you own.
Please get in touch with us directly, so one of our experts can determine which model you have, and provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 27, 2011 | Dyson Vacuums
I have a ruffler for my kenmore sewing machine and im not sure how to use it i know where to put it and everything but im not sure how to use it
Not knowing what model you have, my answer is based on sewing knowledge. The ruffler is an attachment which replaces other presser feet. so you will need to remove your everyday presser foot and put the ruffler on in it's place. You have to make upper/bobbin thread adjustments based on your machine...Do you have your manual???? Happy Sewing.
Jul 23, 2011 | Vacuums
I have a shark iron model G1495N It has a cut in the wire inside the rubber hosing that goes around the cord from the base of the iron When using it yesterday I didn't see the cut and it sparked...
It's probably best to replace the device, when dealing with sparks and exposed wires.
If you're electrically-inclined, feel free to pry it apart (when unplugged!) and see if you can re-attach things, but generally soldering or gluing within an iron is a bad idea.
So... two and a half years is longer than most Hollywood marriages. It's been a good run. Time for a new iron.
May 06, 2011 | Vacuums
How do i change the fill tube
Cut the old fill tube from the lower housing and remove the top adapter from the old tube. Clean the bag and housing to be sure the spout the tube attaches to is clean. Be certain to use the fill tube used in the Generation 3 and 4 models which has a wire in it. Wet the lower few inches of the tube and screw it fully onto it's base in the lower housing. The upper adapter can be attached with cable ties.
Jan 05, 2011 | Kirby G4 Bagged Upright Vacuum
Do alto clarke have a supplier in Australia for vacuum cleaner parts? D T V 7 Thankyou
HI there Vacuum Guru here from VacuumSpot.com.au. Most alto clarke share the same parts as a Nilfisk Alto. We are an agent for these machines. If you use the email link on our site and let us know which model you have we should be able to get you any parts you need.
Oct 14, 2010 | Alto 302000405 Attix 8 Canister Wet/Dry...
Floor attachment starts (green light) and then, almost immediately stops (red light). I have cleared all built-up dust in the unit, but no change occurred as a result.
Step on the blue lever at the base of the floor attachment to separate it from the long wand. Sometimes there is a clog inside at the base that needs to be cleared. Good luck.
Mar 23, 2010 | Fantom Vacums Lighting Canister Vacuum
Is not charging - no red light
Yes, it can be replaced. Can be ordered from Black & Decker. Some people would say it's worth fixing others would not. Don't know cost of battery -- probably under $20.
Apr 29, 2009 | Black & Decker CHV9600 Handheld Vacuum
Beater bar
You may have a bad switch, one part of it is not turning on the brush roll motor. It could also be the brush roll motor.
Feb 08, 2008 | Clarke CombiVac 12 Bagged Upright Vacuum
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
