Question about Frigidaire FTF530FS Front Load Washer
FTF530FS- Washer won't advance, changed out timer and still not working by itself, if I manually turn the knob it cycles fine, cant keep doing that. What is my next step?
huuum
  • 750 Answers
SOURCE: front load washder does not go through with cylce
hello nplooj
welcome,
You said, front load washer would not continue through the cycle. For example, when I turn on the wash cycle, it will stay at that position and does not go to the next cycle. Every time I want the machine to move from one cycle to the next I have to do it manually such as from wash cycle to rinse cycle. The dial won't not turn unless I turn it manually. Please give me a suggestion of what part of the machine is not working properly. Per my understand and my friend told me, it is probably the time is not working. If that is the problem, can I replace the timer myself and how much it cost for the replacement part.
You do have an ATF6000 front load washer?This is made by Frigidaire or Electrolux
Did you get any error code?
Like an "F1" ?
Yes it can be replaced It is part of the,
Control Board,pc ,with housing $ 139.22
Here is the site with the parts.
http://www.pcappliancerepair.com/model-display.php
Let me know how you do.
Huuum,
Please remember to leave a rating!
Posted on Oct 13, 2008
sdmc73
  • 121 Answers
SOURCE: Whirlpool washer stops in mid cycle
check the connection at the main control board top right side just remove the top
Posted on Nov 29, 2008
  • 117 Answers
SOURCE: How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Posted on Mar 02, 2009
  • 98 Answers
SOURCE: Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on Apr 01, 2009
  • 686 Answers
SOURCE: Wash cycle knob turns without controlling wash cycle
it's possible go to www.repairclinic.com and enter the numbers you have posted and it will show you what they are. I have the same problem. What I did was not pretty but it works for now. I broke a piece off of your part#387997 and simply turn my dial that way and then pull the center out to start the wash. Considering a new timer is close to $100+ and it works fine this way , well you know...
Posted on Apr 06, 2009
I have a Frigidaire FTF530FS washer with a problem. The Timer gets stuck in between the drain and the spin cycle. It occurs when the timer dial is about 3 o'clock. I replaced the drain pump, the door...
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Feb 21, 2015 | Frigidaire FTF530FS Front Load Washer
Frigidaire FTF530FS Front Load Washer will not advance through cycles... need to manually turn knob. New timer did not do the trick nor control panel...
Hi Jacquie, thank you for your inquiry! First, when you are referring to the control panel are you speaking about the motor control board? The motor control board advances the timer, and the timer will not advance if it does not sense that the door is closed and securely locked. Therefore, I highly recommend reaching out to an expert technician that can accurately diagnose the motor control board and/or door switch on this particular unit. The servicer will ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 10, 2013 | Frigidaire FTF530FS Front Load Washer
I have a Frigidaire LTF530FS Front Load Washing Machine. It stopped draining and spinning. The drain pump had an underwire from a bra stuck in it. We removed that and cleaned the pump. Hooked everything...
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Since you hear a humming noise, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 28, 2012 | Frigidaire FTF530FS Front Load Washer
Everything works except the dial will not advance to the next cycle, what could be the problem
If what is happening is you start the cycle and the timer does not advance but if you manually advance it by turning it via the knob and it works fine as far it will agitate and drain/spin.
The problem will be the timer is defective and would need to be replaced.
GENE
Sep 23, 2011 | Roper RAX4233PQ Top Load Washer
Will not advance to next cycle
need to replace that timer
Feb 05, 2010 | Washing Machines
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Apr 01, 2009 | Frigidaire Washing Machines
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Frigidaire FTF530FS Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
