Question about Crosley Np4 Np4 Cr249 245 246 78 Rpm 901d3
I borrowed a crosley cr-246 to copy some lp's to cd's. I do not have a manual. I would like to know basically how to work the machine to do what i want - copy the lp to the cd. all i have right now is the power on and a blank cd loaded...nothing else seems to work.
  • 8,197 Answers
You can get the manual on the link below.
http://www.crosleyradio.com/Manuals/CR246_Manual.pdf
Posted on May 21, 2011
Yamaha support i dont know how to work this thing
Well, the users manual is a good place to begin.
http://usa.yamaha.com/products/music-production/recorders/aw1600/?mode=model
Select the "Support Button" to see the user manual download.
If you have never used a mixing board before, it can be intimidating. It really is not that difficult to figure out the basics of studio mixing. Textbooks on mic placement and setups will help some, but a great deal of it comes from developing an ear for the music and the instruments as well as the microphones. You should find many Youtube videos on the subject of mixing/recording, look for the one who presents information in the manner you best understand it. At it's best- it aproaches the level of an art form.
There are people who have held well attended art exhibitions with finger paints- You have the first piece of the puzzle to making your own art that is above the level of finger paints- a reasonable mixing/recording station. You do not have to fight the equipment to get it to work. The manual will outline what you can do with the machine, but you have to be open to it. You have to apply the things you know how to do as a discrete step with other gear, such as a mix CD from your computer or a mix tape from your home stereo. You set the EQ on your home stereo. It is now all at your fingertips in one device. If you were able to sit down at a piano or pick up a guitar and play deftly the very first time you did so- this could be a walk in the park.
The reality is it will take time. If you do not fully understand what the system can do- it you get it to do what you want it to do- it matters not what features you are not using. You can always learn new tricks as you go.
Feb 21, 2012 | Yamaha AW1600
GPX Karaoke Machine with AM/FM radio and cassette, Manufactured 1/2001 Model C1550 do not know how to hook up to TV/VCR ?
On the rear of the unit, the RCA jack on the lower left corner of the jack panel should be yellow and marked Video out. take a RCA to RCA plug into the video out on the unit, then plug the other end into Video in on the TV.
I'll attempt to send you the manual thru the link below:
http://www.gpx.com/owners_manuals/JM250S-IB.pdf
Good Luck, and don't forget to rate the answer. Let me know if this doesn't help.
M
Sep 21, 2011 | Digital Products International Karaoke...
Drum kit won't power up
Get a voltmeter and check the power to see if it is working at the plug. the voltage should be 12vdc. If you don't have a meter, just take the power adaptor to radio shack, or any electronics supply house.
They'll check it for you. below is a copy of the manual. Good Luck!
Download Yamaha DTXPLORER User manual
Sep 01, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
Need a manual for old hammond organ model 122126 romance model or 1977 or 1978
You might try the ORGANFORUM.com as there are a lot of organ players there and quite a few with Hammonds. Finding an original copy is probably out of the question, but a duplication probably can be found.
Jul 15, 2011 | Hal Leonard Classic Hammond Organ Know the...
Crosley music centre has fault on record player due to turntable not working
If the unit is belt driven, (sometimes hidden) that is common cause of turntable failing to turn. Either belt comes off or is deteriorated.
Apr 27, 2010 | Crosley CR711-BK AutoRama Retro Turntable...
What is the recommended height for humbucking pickups on a epiphone lp 100?
the closer to the strings the greater the magnetic pull. it's a personal variable to the player.basically how aggresive of a sound you want
Dec 30, 2009 | Epiphone Les Paul 100 Electric Guitar
I have no clue how to play a cd there... I mean, the radio is no problem, i can turn it off and on, can search for a prog, no big deal. but how do i start the turntable? maybe someone even has a manual for...
to start a turntable press Start button and put an arm with a needle across record, if there is no start button, just put arm across record - it should auto-start; to play cd put it in and press play (play button shoud be near the cd slot, together with stop, skip and others)
Oct 14, 2009 | Crosley CR711-BK AutoRama Retro Turntable...
Looking for owner's manual for streetbox sb-246
All Zoom manuals here:http://www.zoom.co.jp/english/download/manual/english.php
Aug 28, 2009 | Music
Older Cr 1604, powers up but no output, suddenly after gig.
The power supply is located in that area on one side. It is possible that one of the output op-amp ICs has failed. There are a number of 4558 ICs used as output buffers for this unit. Without seeing the unit and testing parts of it, I can't say for sure. These are not the easiest to work on as they are really compact. Where are you located? I may be able to suggest a service center in your area. The repair cost should not be too bad. The parts are cheap and readily available. Please update this with your location. Thanks, Dan
Jun 06, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Crosley Np4 Np4 Cr249 245 246 78 Rpm 901d3 Logo
115 people viewed this question
Top Crosley Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Crosley Music Expert? Answer questions, earn points and help others
