Question about Dryers
What amp breaker should a 700 series Kenmore elect dryer be working with?
    Brigadier General:
  • 3,301 Answers
20amp as far as your house circuits
Posted on May 21, 2011
I have a Kenmore Series 70 Dryer and it keeps blowing the main breaker on the electricity panel - the main fuse is 20 amps do i have a dryer or fuse issue ?
Your dryer needs at least a 30 amp breaker to operate correctly. Changing to a 30 amp breaker should solve your problem. Hope this helps
Sep 01, 2011 | Dryers
My 70 series dryer the heating element is not working. I checked the heating coil for continuity and it is holding 12 ohms, the fuse has continuity and it has power. Flipped the breaker to se If that was...
your voltage is not right as it should be 220 volts, check the outlet to see if you have 220 if you do then its the cord, if not then it is either the outlet or the breaker-panel, to check panel remove panel and test both legs of the breaker you should have 220 if not then replace the 30 amp breaker. Tim
http://www.ehow.com/how_7403710_replace-kenmore-70-series-dryer.html
May 27, 2011 | Kenmore Dryers
I have a Kenmore 300 series elect. dryer that keeps tripping 30 amp breaker. Have already changed breaker wiring going from box to dryer and installed new motor.
Check your load/AMP capacity.
If you have other electrical appliances on ie. Iron, Heater, toaster, Kettle these will contribute to the over loading problem.
Old homes sometimes only have 40-80 amp capacity
Apr 19, 2010 | Dryers
Need owners manual for sears kenmore elect dryer model 700.
Please visit THIS LINK.
Enter the FULL model number - then after choosing OK, the link to the manual will appear on the right side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 24, 2010 | Kenmore Dryers
90 series kenmore elect. shuts off
are u sure it does this only in that cycle? if so the only thing i can think of is a timer, inless the thermostat is shutting it down because the element is getting too hot.... whirlpoolpartssurplus.com mark ... give me a call free
Jun 26, 2009 | Kenmore Dryers
My 700 series Kenmore Dryer wont heat completely.
If the dryer has been cleared of lint. the lint filter area is clear and the vent is fine then the timer is probably bad. Why? because a lot of current goes through the timer and most of the time the contacts in it get burred or burnt. Unless you have a bad breaker I would advise replacing the timer.
May 19, 2009 | Kenmore 62602 Electric Dryer
Kenmore series 90 dryer kicks breaker often. Draws 20.9 amps
Well do the math.... 5000 watts divided by 220 volts =
22 amps
Feb 06, 2009 | Kenmore 63942 Dryer
Kenmore 400 series electrical dryer
I have a 400 series kenmore dryer that just quit running after 10 min. into cycle. breaker in house checked and is ok but no power to dryer. what could the problem be
Oct 18, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Dryers Experts
