Question about Dishwashers
I have a Kenmore Quiet Guard 4 dishwasher that stopped working. The "clean" green light flashes continuously, although the dishes are not clean.
  • 1 more comment
  • blue714br May 21, 2011
    It seems to be working. What would have caused this?
    Easy fix to troubling problem. Once I figure out how to give thumb's up, you got 4 of them. Very pleased with the responses and very quick resolution!
    Kevin was very quick and right on the mark to resolving my problem. Thank's, Kevin
  • Dishwashers Master
  • 1,902 Answers
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Posted on May 21, 2011
  • Kevin White
    Kevin White May 21, 2011
    Great, its
    solved, this usually occurs due to problem in heating element or lack of heat.
    This can be reset every time by following the same procedure. Please get back to
    Kevin
    Great, its solved, this usually occurs due to problem in heating element or lack of heat. This can be reset every time by following the same procedure. Please get back to me if you have any other questions.
    Kevin
  • Kevin White
    OK...thanks...I believe you have to accept this to give a 4 thumbs rating :)
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
I have a Kenmore Utraguard Quiet Wash 4 dishwasher. The green "clean" light is flashing and I am unable to start the dishwasher. Any ideas?
Try pushing the Heated Dry and Normal Wash buttons back and forth several times. I had the exact same problem and read on the internet this solution. It has worked!!! The dishwasher is running right now.
Jun 18, 2008 | Dishwashers
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Quiet guard 3 dishwaher
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
181 people viewed this question
Top Dishwashers Experts
