Question about Polaris Ranger RZR Ride on Toy
Ranger shuts off after 2 minutes then "cools down" and runs for another 2 minutes. WHat could cause overheating to shut off vehicle.
    Genius:
  • Polaris Master
  • 1,508 Answers
Known issue with these you will need the motor and board upgrade kit, let me know if you need me to order one for you
Posted on May 14, 2012
What causes engine to ABRUPTLY shut off while driving ?
2004 Ford Explorer Engine Stalls/Cuts Out While Driving: 31 ...
www.carcomplaints.com/Ford/Explorer/.../engine/engine_stalls_cuts_out...
... 2013 · 2012 · 2011 · 2010 · 2009 · 2008 · 2007 · 2006 · 2005 · 2003 · 2002 · 2001 · 2000 ... 2004 Ford Explorer engine problems: engine stalls/cuts out while driving ...to overheat and slide out of its socket, causing the engine to shut off. ..... Suddenlyat 30-35mph, my engine just died and i cannot control the steering wheel.
2005 Ford Escape Engine Shutdown While Driving: 24 ...
www.carcomplaints.com/Ford/.../engine/engine_shutdown_while_drivin...
The 2005 Ford Escape has 24 complaints for engine shutdown while driving. ...January 22: Ford Ranger Driver Killed by Takata Airbag in South Carolina news ' 2 days ago; Ford Focus Door Latch ..... I was 80 miles from home when the engine shut off. .... No one could seem to determine the true cause of the problems.
Ford Ranger Stalling/Dying Problems - Edmunds.com
forums.edmunds.com > Ford > Ford Ranger
Nov 2, 2007 - 31 posts - ‎21 authors
Learn more about Ford Ranger at the Edmunds.com Car Forums! ... cut off a couple of times then it started happening more frequent while driving. ..... the other day I was driving down the highway and it just shut off, no warning .... 2000. when it gets overheated the circuit shorts and causes the engine to die. Ford Expedition engine cutting off while driving
Oct 24, 2009
Mercury Mountaineer Start Stall Idle Problems
Oct 1, 2007
More results from forums.edmunds.com
Jan 27, 2016 | 2003 Ford Ranger Regular Cab
Ranger shuts down when extra hot, after it cools will start again
is vehicle overheating or when it gets really hot out it stalls
Aug 27, 2015 | Cars & Trucks
Whenever I play a video on my laptop it shuts down after a few minutes?
Many laptops don't cool as well as they should - try elevating the rear of the laptop - heavy video usage could be causing the shutdown.
How to Fix Overheating and Shutting Down Laptop
Feb 18, 2015 | Computers & Internet
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
My mothers 800 Series drier shuts off after running for about 10 minutes. After it cools down it can be restarted, then shuts down again. It has two temperature sd swtiches on the air exhaust. Could one...
there are temp sensers to shut the element off to control the temperature(could be overheating) as well as temp senser to shut it off if it overheats either one could be bad.
Feb 26, 2011 | Kenmore Dryers
Over heating
If this vehicle has the original or old(defective) thermostat, this can cause overheating if its stuck closed(defective). The engine cooling fan has a clutch, If defective the fan will just spin, not fast enough to cool the engine and cause overheating. The radiator is clogged, can cause overheating. A simple check for the radiator is when vehicle has been running awhile, engine is hot, shut the vehicle off and open the hood and carefully reach your hand down between engine fan and radiator and quickly palm the radiator at the top, middle, and bottom and if the warm temp by feel is about the same, most likely the radiator is not the problem. Good luck, best regards.
Feb 04, 2011 | 1997 Chevrolet Blazer
TV SHUT S ITS SELF OFF
Is the unit free of dust and debris from dust? If its overheating there are may factors that play in this
1. fan spinning but not enought RPM rotations per min ( not fast enough)
2. room temp
3. dust
other then that some capictors must have exploded inside withc will cause a overheat.
Apr 22, 2009 | Samsung HLR5064W DLP Projection TV
Overheats and shuts down after about 20 minutes
Usually when a CPU overheats it shuts down and after it cools down you can re-boot it again.
Continual overheating will eventually cause the CPU to fail.
The overheating is usually caused by blocked vents and or dust build up on the heatsink and/or fan. Remove this dust from the heatsink and fan and this should fix your overheating problem, unless you have a faulty fan, in this case you will need to replace the fan.
Feb 18, 2009 | Dell Inspiron 2650 Notebook
Shut down
check coooling fan too. or replace the heat sink.
the problem that i see in your case is overheating.
Jan 15, 2008 | Toshiba Satellite A15-S157 Notebook
Polaris Ranger RZR Ride on Toy Logo
223 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
