Question about Minka Aire Ceiling Fan
We have a Minka Ensemble F816-1-BN with wall unit remote control tranmitter. Power is going to the wall switch but the fan and light will not go on.
  • 5,370 Answers
If both the fan and the light are not working, it is likely a connection issue. Lower the fan canopy and/or housing, and check to see that all the wires are connected . As you said wall switch is getting power so its loose wire at the canopy. The remote receiver is in the ceiling canopy of the fan. Remove it and wire the fan as you would without it. Click this link for more troubleshooting. http://technoanswers.blogspot.com/2011/05/fan-and-light-not-working-on-minka.html ----------- This should help.Thanks.Helpmech.
Posted on May 21, 2011
My minka wire light does not work is it the dimmer switch on the fixture
Check for 120Vac cming into the light fixture, if its there, the problem is your fixture, the fixture switch, or the way you wired it into the circuit.at the light fixture
Aug 17, 2014 | Minka -Aire Brushed Nickel Remote Control...
When I program the remote then the wall switch stops working. How do I fixit so both work together?
The setup should be the same for both so try different code setups to see if both will work together
May 30, 2014 | Minka -Aire Brushed Nickel Remote Control...
Minka aire wall control not working
It comes with a hand held remote. Unless you have the compatible wall transmitter, you'll only be able to use the hand-held remote. The switch on the wall has to be on for the remote to work.
Dec 14, 2013 | Minka Concept II Ceiling Fan
How to i replace the light bulb in the minka aire ceiling fan
This is the concept f518-bn or 519-bn with recessed light.
According to the manual you twist the clear plastic cover counter clockwise. This is on the opaque white lens cover itself.
Manual is found here:
http://www.minkagroup.net/Admin/UploadFiles/F518-English.pdf
Mar 15, 2010 | Minka -Aire Brushed Nickel Remote Control...
I currently have 2 switches on the wall for a ceiling fan(this was pre-installed when I bought my new home, but my Minka
The red and white should be hot all the time for the fan to run even when the light is not in use. The black and white wires are used for the switch on the wall to turn the light on. Hope this helps.
Apr 25, 2009 | Minka -Aire Brushed Nickel Remote Control...
Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Aug 22, 2008 | Minka -Aire Brushed Nickel Remote Control...
Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Jun 01, 2008 | Minka RC120 Remote Control
Minka Aire Ceiling Fan Logo
148 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
