Question about Panasonic Audio Players & Recorders
I have a panasonic sa-ak300 and it wont turn on it shows f61 then shuts back down.... what can i do to fix it? im not very good with electronics and short on cash i just need a quick simple fix thanks
  • 4 Answers
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
CHANGE STK --------IC
Posted on Mar 27, 2008
  • 4234 Answers
SOURCE: Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
Posted on May 15, 2008
zair
  • 82 Answers
SOURCE: Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
Posted on Jun 01, 2008
nuwan chinth
  • 111 Answers
SOURCE: panasonic sa-ak25
the problem is F61 is speaker protection mode on.
fault with your audio power amp section.
i can help you.
nuwan.
Posted on Jan 15, 2009
SOURCE: panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
Posted on Aug 26, 2009
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
My panasonic stereo system sa-ak300 has not been responding correctly when i turn it on. When i push the on button it shows F61 on the display and goes automatically off. Whats the problem? What do i have...
Have you looked at the manual?
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Aug 03, 2011 | Panasonic SC-AK300 CD Shelf System
Panasonic Dvd stereo system model number SA-VK960 power supply is defective. is it possible to repair?
Your Panasonic SA-VX uses a Switch Mode Power Supply ( SMPS ). Do not ever attempt to fix it yourself unless you are well versed in electronics. ou can damage the system seriously. Seek professional help.
Mar 10, 2011 | Audio Players & Recorders
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
F61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
Feb 22, 2009 | Panasonic Home Theater System System
I have a f61 fault code on my sa-ak600 panasonic audio system
Replace IC500 on power circuit board.
The board at the bottom with heat sink.
STK470-090 voltage regulator Sanyo original.
Dec 22, 2008 | Panasonic SC-AK300 CD Shelf System
Panasonic SA-HT940
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
F61 error
Hello....
Isolate problem by disconnecting Amplifier ic (RSN),if f61 still appeares after disconnection of RSN ic ,than check voltage supply rails ,may be one of them has irregularities.
Gopali
Dec 14, 2007 | Panasonic SC-AK300 CD Shelf System
How do I solve Panasonic SA-HT800V error code F61?
unplugged a Panasonic HDTV plasma for four minutes, plugged back in and Now the DVD does not work.
How to reset?
Aug 28, 2007 | Panasonic sa-ht800V Home Theater Audio...
87 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
