Question about RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA CUTTER 1-5130- 1
Yes sir I own a thermal dynamics cuttmaster 52 and connot get the machine to work .The main problem is when I pull the switch the far red light starts to flash. any help would be appretiated
How far do I need to take apart to see if is a loose wire
wires at at the top of the light so just loosen of the part above the fan and slide it up to check the wires and connections , or pull the switch from the wall and check there
REmember that the wires will be live so turn off the mains first
Sep 27, 2016 | Hunter 52" Ceiling Fan With Light And...
Optoma hd73 the temp light is red and wont start fans or light just the standby light on flashing could this be a ballast issue or thermal sensor?
if you projector auto shut down, and Lamp LED Light - Check Lamp - Check Lamp Driver - Check Main Board b. Temp LED Light - Check Thermal Sensor - Check Thermal Switch - Check Fan
May 12, 2016 | Office Equipment & Supplies
Oven keypad is completely black but inside oven lights work. does keypad have a separate fuse?
Yes. Many of these have a display thermal fuse that is part of the wiring harness that connects to the board... it should have continuity. WP4451042. Almost all models have what is called the "oven shut-down thermal fuse" which is on the back of the machine ( you have to pull it out of the wall and remove the back panel) and looks like this KitchenAid Range Stove Oven Thermal Fuse WP9759242
Dec 06, 2014 | KitchenAid KEBC208 Electric Double Oven
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
The exclamation point, the red dot, keeps popping up and it is also red on 85-5.9 and only air is blowing out
Try and replace the swirl ring. We had the same problem and it fixed it. They cost around 35 bucks
Dec 10, 2010 | RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA...
Atwood Model # GC6AA-10E. When I try to start unit on gas it tries to start 3 times and red warning light comes on. When I try electrical the red warning light comes on. Have cleaned the contacts on...
Normally the red light stays on for hydro operation, so within 1/2 hr or so you should have hot water. Red light on gas means problem lighting. A few things to check. Make sure switch at back of water heater is on as well as breaker in panel, for hydro operation.
As far as gas side goes, try going outside and drop cover down, and pull the connectors of and on a couple of times at the spark module, just to make sure you have clean contact, and have someone try switch after, and let me know if it's at least trying to spark. If still not working, there should be a thermal cut-off switch in the brown wire running to center area of water heater to the thermostat, and ECO. ( where square piece of black foam covers them) That thermal cut-off has a clear plastic sleeve over it. Take that out of the circuit. Simply pull it apart at both ends, and then connect wire from spark module directly to THERM/ECO, where it was before.( your just eliminating that piece, and going direct.) See if it lights now, and let me know. Do you have a 12 volt test light, or multimeter? Also, with it turned off, take your finger and push in between spade connectors on the THERM, and ECO, and make sure there isn't a little reset in center that has tripped.
Jan 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Mitsubishi 52725 52525 Red Light turns on
the problem might be the thermal sensor on the light engine. with all the work you have done on this i would suggest taking a look at the thermal sensor. these are known to go out.
Apr 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Light not working by pull chain or remote.
I would try removing the remote part. Connect the two main (light & fan) wires direct to your house main. Then if the pull chain works then you just need a new remote unit.
Feb 13, 2008 | Heritage (5BUW52NK2YQ) 52" Ceiling Fan
RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA CUTTER 1-5130- 1 Logo
80 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
