Question about Dryers
I have an Accutek ARJ-4601R it stopped powering the fan though the lights on the controller are on. I opened it up and on theback of the controller board there is 1 loose wire and if I move the other 2 wires it sometime starts moving. Does anyone have a wiring diagram, and also how do I pull out the controller without breaking it?
  • 79 Answers
SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Posted on Jun 11, 2008
  • 37 Answers
SOURCE: Replace exhaust fan with fan & light?
Let's say you originally only had one switch (to operate the fan). And at the fan you have only one black, one white, and one ground (bare or green). You can still put in a fan/light combo. but both the light and the fan will always come on together when you flip the switch. To do this you'd connect the black from the switch to the black AND the blue on the fan and connect the white from the switch to both whites on the fan and connect the ground from the switch to either a green or bare wire on the fan or to a green screw on the fan housing somewhere (whatever is available).
Posted on Jan 29, 2009
  • 235 Answers
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Posted on Jun 30, 2009
SOURCE: wiring pull chain 3 way switch for ceiling fan
I am in the middle of doing this now. 1 = Yellow; 2 = Blue; 3 = White; and L = Black.
Posted on Oct 06, 2009
  • 57 Answers
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Posted on May 16, 2010
My Accutek not blowing out the air from the fan what is wrong with my fan
There is an 'enter' side and a 'blower' side to each fan. Is it spinning the proper way?
Jul 02, 2015 | Accutek AOJ-1601 Stand (Pedestal) Fan
Agent in Malta for accutek fans
www.accutek.com.tw/
Consider asking the company if they have an agent there.
Oct 20, 2014 | Dryers
I have an Accutek fan that is not working. Where can I have it fixed in Cape Town? I would like someone to look at it to see if it can be repaired before I incurr costs?
I also have the same problem with my Accutek fan. I think it is the bearing that is going as it is making a noise .It is like running and then jamming as something is restricting it. I also live in Cape Town and looking for someone to fix it.
Jan 24, 2014 | Accutek Dryers
I have a A0X-1202 Accutek fan, it wouldn't start. It worked fine before but today it just won't start. Can it be fixed? What possibly could be the problem?
1st, remove the poer cord from your fan and determine if you have any breaks in the line by checking the voltage ( 120 volts) coming from the bare wires when it's plugged in. If nothing registers on your volt-multimeter, you can easily repair the cord or just replace it. Check to see if that works, and if not, ask me the next step.
Sep 21, 2012 | Accutek AOJ-1601 Stand (Pedestal) Fan
Fan not spinning
clean your fan motor. remove carefully part by part(your fan motor, the coil and the rod). remove all the dirt. put machine oil at the rod, front and the back part. try to spin it. oil it and spin, do it again and again until the rod spin smoothly. and then put back those part as before you 'open' the fan. but remember, do not do this while your fan plug is still plugged to the power source. or you will be dead instantly. for your safety, you know. so be careful. last step, try it! :) i hope this will help you in fixing the fan.
Jul 13, 2009 | Accutek AOJ-1601 Stand (Pedestal) Fan
Accutek AOJ 1601R fan wouldn't start
hi there,
it always can fix,there are several factror to check,you should have a multi tester to use to check the circuit.it might be on the switch,
cable or on the motor.
open the control box of the fan,there are set screw loosen this and you will see the connection of electrical connection of cable supply and the swicth.
set tester on rx1 check continuity of the cable plug supply,red rod of tester on plug take one wire,black test rod on the other end of cable plug.this other end of wire is on control box.see if pointer of tester move on to no.10 or 20ohms if move its good.try also on the other side of wire.if does not move replaced the wire.
if you can see a fuse check this,by tester
on rx1 attached red test rod on one end of fuse black rod on the other end,if move the pointer its good but if not,replace fuse,actually all fan motor have thermistor fuse inside the motor,it was mounted on the inner side of winding of
motor it look like a resistor or sometime a form of small square resistor has two terminals,to test this, red test rod on one terminal and black test rod on the other terminal if pointer of tester does not move replace thermistor.
to get the termistor fuse you should open
the motor,this is not easy job.but small pc. of motor will give you knowledge how to fix your small appliances.,on motor there are four lock in bolt,before you can pull out the motor disconnect the wiring from the switch cut this
by cutter plier leave a small color lead of wire
when you cut,allow you to remember the connection when putting back.when you dismantle the motor,loosen the four lock in bolt and pull out the winding on motor case
on winding cut the plastic strip,find the thermistor fuse,this was insulated,careful to cut small wire this are all terminal of motor
replace the thermistor if busted.
put back and try to run your fan again.
unplug your fan before doing this this should be done by technician,have anice day rate my fix thanks a lot.
Jun 12, 2009 | Accutek AOJ-1601 Stand (Pedestal) Fan
Lost remote control
Maybe searching EBAY.COM or going to your nearest repair shop.
Sep 06, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Accutek aoj-1601 stand fan problem
An electric motor shop may be able to rebuild the motor for you, or you may be able to find a motor with the same ratings. Chances are this would be pricier than a new fan though.
Jun 23, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Accutek stand fan just hums, won't turn
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
Jun 15, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Dryers Logo
165 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
