Question about KitchenAid Dishwashers
I am looking for a repair manual for a Kitchen Aid KUDL02FRSS1. The spring broke on the door.
4 Suggested Answers
  • 2326 Answers
SOURCE: broken door spring on kitchenaid dishwasher
You will find the parts you need here by entering the model number and search for the part.
They will be able to help you with the installation as well.
Posted on May 07, 2008
ginko
  • 19396 Answers
SOURCE: KITCHEN AID STAINLESS DISHWASHER MODEL
Hi.
Your husband must check wiring harness from electronic control to door lock solenoid.
The solenoid should also be tested reading Ohms with a multimeter.
Here parts and diagrams: KUDS02FRSS
Posted on Dec 02, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a Kitchen Aid dishwasher model #
Hello, welcome to FixYa.
Based on your description, I'd say you are correct ( yes you can get the parts on-line and I believe most homeowners aka do-it-yourselfers can repair this ). Either one or both of the door link kits/springs broken. It's an easy enough repair, though the unit does need to be pulled out, slightly
First, slide the entire unit out from the cabinet a couple or three inches and you`ll see the plastic roller assembly and rope ( except yours is likely broke...at least one by the sounds of your description ) attached to the side.
**You`ll need to insure your connections will allow you to pull the unit out however, otherwise they - water, power, drain hose - must be disconnected to prevent any damage.**
If you have any reservation to performing this repair on your own please call in a qualified appliance technician.
The parts ( # 1059756 @ repairclinic ) come in a kit as I alluded to and will look like what I attached below...
These are available at most brick & mortar appliance part locations or on-line vendors such as "repairclinic.com" "searspartsdirect.com" to name a couple.
They range in price for around $20, or you can just purchase the rope/link seperately for about $4 part# 1159210 @ repairclinic.
I recommend replacing the entire kit and checking the spring itself, if it looks ok and not stretched or broke it is likely ok...they are seperate from the kit ( # 830967 door spring @ repairclinic as well )
Hope that helps move you forward. Thank you for visiting "fixya" today. Please take a moment and rate the solution provided here or a testimonial if you feel warranted.
Let me know if you require further assistance and good luck.
Regards,
Macmarkus :)
Posted on Oct 27, 2011
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
Kitchen aid torsion spring
I looked up the parts break down for this model there are 7 different ones your last 2 digits are missing this unit dos not use torsion springs the MW door should have a brown arm riveted to the door that goes into the frame this activates a switch
Feb 18, 2015 | KitchenAid Kitchen Aid 30 In. Stainless...
I have a Kitchen Aid dishwasher model # KUDSO2SFRSS. When I open the door it just falls to the floor. The spring has broke. Is that an easy repair, and can I buy the repair kit online?
Regards,
Macmarkus :)
Oct 27, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
I'm looking for repair manual for range made by Kitchen Aid
web search-kitchen aid range manuals- or -kitchen.manualsonline.com
Oct 15, 2010 | Microwave Ovens
Kitchen Aid Model KUDPQ1FLSS5 door counterbalance issue
One of the counter bakance springs OR the adjuster for it let go. I had a similar thing where the adjuster which was a thin metal "T" thing that screwed up into the spring as an adjuster folded and fell out of the spring.
Remove the bottom dress cover at the tope kick of the dishwasher. The springs are all accessable right there. The problem will be obvious. Just compare the two sides.
I had to beef up the "T" adjsuter in mine as it was too weak to continue holding in the spring.
One turns it into more or less coils of the spring to adjust the counterbalance.
Apr 21, 2010 | KitchenAid Dishwashers
Fix door spring how to connect it
door spring broke in kitchen aid dishwasher
Apr 10, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
The spring on the door broke. How do we fix it?
get a spring from a kitchen aid parts supplier and relace it
Sep 28, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
50 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
