Question about Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
Hp will not boot up when seagate freeagent external is plugged in, only if plugged in after system is up and running
  • Seagate Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 21, 2011
How do I work on my data on the Seagate FreeAgent 2TB GoFlex Desktop USB 2.0 Hard Drive as my computer memory is at capacity. I want to be able to use my external hard drive as an extension of my computer...
Assuming you are using a Windows operating system, you can just plug it into your computer's USB ports, and the computer will recognise it as another hard drive.
Instructions:
Double-click on 'My Computer' and take note of what drive letters are there (C:, D:, etc.) before you plug in the Seagate Freeagent.
Plug in the Seagate Freeagent. You'll see the new drive, likely E: or F: (depending on what is already there before you plugged in the Seagate Freeagent)
Double-click on the new drive, and it'll open up and you'll see the files stored on that drive. You can drag and drop files and save to this drive like any other folder on your computer.
Mar 06, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Its slow, does not boot up after shutdown (unless re-plugged again) disconnects randomly and has hard time searching files!
download the seagate utility from seagate and run a diagnostic. It will tell you what's wrong with the drive. Your drive should have come with this software on it.
Oct 25, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
500 GB Seagate freeagent classic - windows 7 won't start when power cord is connected. Okay to connect after boot up and HD works find. Is there a workaround that will allow the external HD to remain in...
Most likely the problem is that your computer is trying to boot from your external hard drive and that why windows 7 wont start up but it is a very easy fix. with the freeagent attached start up your computer system and when the first BIOS screen is displayed press either the F8 key or the ESC key to enter BIOS setup it should say on the screen which button you need to press. Once you press the correct button the BIOS set up screen will load there should be tabs at the top and select the boot tab, under the boot tab there will be a list of devices in the order that the computer will try and boot off of them all u need to do is move your freeagent to the bottom of the list and every thing will work perfect.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer cannot find external drive
This sounds like it might of formatted the hard drive aswel and now needs partitioning.
Go to control panel then system tools then computer management.
on the left click disc management and see if it shows in this.
if it dont then you need to take the hard drive out of the case, and plug it into the computer inside via the sata cable and partion it in the boot options.
hope this helps
please rate
Feb 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard Drive Dropped
Turn off your computer and then plug in the FreeAgent external drive. Then try turning your computer on, it should read.  If it doesn't I would go to the Seagate website for troubleshooting.
Jan 31, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freeagent desktop external hard drive will not power up
I have my own Seagate hard drive and with mine you have to plug it into the computer and power source for it to power on.
Jan 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows 98 driver for FreeAgent
If your PC is still running Win98 then it probably has a USB version 1.0 port. I don't think the Faster USB version 2.0 devices will work properly even if you have the correct driver - i.e. you have a hardware version conflict. Try Purchasing a USB version 2.0 Daughter board for the PC and plugging the Seagate drive into that iinstead.
Jan 01, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive Logo
113 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
