Question about GE Dishwashers
Dish washer Hi there, Last time I started my dishwasher, clear water spilled out in a large amount. We pulled the washer out to realize some plastic parts underneath had totally smashed down. Is it possible to replace those parts, or do I need to buy a new washer?
  • sanaz62 Aug 15, 2008
    It's a GE, model number is 165D5450P002. Where do I get the parts, or who do I need to call to get them and fix it?
    Thanks
    Sanaz
  • 88 Answers
Yes youcan replace them just give dishwasher name ?
Posted on Aug 15, 2008
Dishes won't come clean
Check your water inlet for the right pressure and then the water float valve for the right amount of water in the tub for washing. The tub has to have the right amount of water in it to pump it up to the top. It is also possible that the pump has debris in it that is restricting the flow. Clean out the screens and check the bottom of the washer tub for debris at the pump inlet. Use white vinegar to clean out your washer. Start your washer - open the door and pour in a lot of vinegar. Let it run for a few seconds and stop it. Let the vinegar work on the scale and debris. Start and stop it several times during the day - not completing the wash cycle until in the morning - after it has sat with the vinegar 10 -12 hours.
Mar 03, 2014 | KitchenAid 24 in. KUDP02CR Built-in...
I get major residue and (scum and white spots) on my dishes, along with food being sprayed all over them. They seem to come out more dirty than when I put them in!!! I end up washing dishes in the...
Hello, W/D here.
There are cleaning products out there that "sort of" work, some better than others, but here's how to get it cleaning like new:
1. Clean the spray arms nozzles and slots. If the spray arm can be removed, take it off, and clean it over the sink. I use a regular paper clip, bent into an "L" shape, and use it like a rake to pull debris out of the slots on the tips of the spray arms, and poke any stuck debris back through the nozzle holes, then backwash the nozzles and slots with the water from the faucets, back towards the opening where the spray arm was attached. Take your time; it's far better to do it right, than to have to do it over. For those spray arms that cannot be removed, use the paperclip to rake out as much debris as possible, but realize that they will probably need to be cleaned over the period of several cycles to get it all out. Same for the nozzle holes.
2. Add to the bottom of the dishwasher, spreading evenly and in this exact order:
1/2 cup of salt
1 cup of baking soda
2 cups of white vinegar
The mixture will foam up and clean your screens and sump of debris, soap scum and food particles.
When the foaming has ceased, add 2 cups of bleach to the washer sump. Run the water source closest to the dishwasher water supply line (usually the kitchen sink) until it is as hot as it can get, then start the washer on it's sanitary cycle.
The best washing advise for those daily runs is to always heat the water by running the sink water first, and to use a good rinse aid. Lastly, I recommend that folks use the least amount of detergent possible while still getting the dishes clean. We presently use about 25% of the recommended amount; a little in the cup, and a sprinkle on the door, heat the water up, and off we go. The dry detergent is abrasive and often contributes to cloudiness seen on the dishes and mostly glassware. Cut your detergent to 50% to start with, and adjust up or down from there, until you have the right amount for the quality of water in your area, and the demands of your washer.
Here's hoping that you find this useful.
Best regards, --W/D-- Please take the time to rate our solutions so that we may continue to improve in helping others. Thanks.
Feb 23, 2011 | Danby DDW2406 Stainless Steel Built-in...
My dishwasher no longer cleans my dishes and white spots remain even when jet dry is being used.
Dishwashers rely upon water circulation. Make sure there is nothing blocking the pump receiver at the bottom of the washer, like paper labels from gars, or large food pieces. It also relies upon the proper amount of water in the washer. After the washer fills and starts its cycle, squeeze the handle to open the door but do not open the door until all the sound has stopped. The water level should be visible and close to the top edge of the basin. Don't worry, opening the door after the pump has stopped will not spill water on the floor. If the water level is good and you are sure there is nothing blocking the pump receiver, check the stem in the center of the basket.
Sep 20, 2010 | Dishwashers
Dish water not emptying out after a full cycle.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 22, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
I have water leaking from bottom of dishwasher motor area..the dishwasher started making a whinning sound and then washer cycle would'nt work. it happened after i discovered a broken glass in washer.
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. You should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 08, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
White powdery residue on dishes
Decrease the amount of rinse aid (jet dry) your dishwasher is dispensing.
Sep 02, 2009 | Amana 24 in. ADB1500AWS Stainless Steel...
Poor cleaning leaving deposits,dishes feel dirty
The problem for the spots is hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Aug 04, 2009 | Thermador DW44Z Built-in Dishwasher
Glassware and dishes getting water spots lately.
I think your dish washer is starting to go out. We have a Kenmore dish washer (unsure if the model is the same), it started with not cleaning the dishes well to not sanitizing and now it doesnt dry. We are actually replacing ours today. We we noticed that it wasnt cleaning properly (water spots, or not rinsing well) we too added Jet Dry thinking that that would solve it. We soon discovered that it didnt help at all. Hope this helps you.
Mar 17, 2009 | Kenmore Dishwashers
Kitchenaid dishwasher will not drain completely model kuds25shwh1
there is a plastic cover in the back over the drain under the dish tray,, pull out the tray and in th back of the dish washer there you will look down and see a small strainer that is plastic, you will need a 1/4 inch nut driver to remove the cover,, after you remove it there is a couple of pastice peices to take out that are just laying there, remove them and there is a small blade that is there to help cut up food that has been left behind on the dishes,, you can remove this and under it you will find the drain hole,, clean out any debris that is in there, if you have to you might want to take tha bottom cover off the lower front of the dish washer take off the drain hose and flush water thru,, adfter this and then reinstalling everything the way it was, run the dish washer if it still has water sitting in the bottom it is time to get a new pump, it is bad and not pumping,,, you may wish to have an appliance person out to tackle this job,, good luck
Jan 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
FIX:
I started the rapid advance service diagnostic feature:
1.Close dishwasher door
2.press "Hi-Temp Wash"
3.press "Energy Saver Dry"
4.press "Hi-Temp Wash"
5.press "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Jun 13, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Open Questions:
Dishwashers Logo
147 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
