Question about Dryers
How can I change my exhaust vent on my dryer from back to side exhaust
    Problem Solver:
  • 19 Answers
You can use this dryer vent periscope to turn the exhaust around to the way you want it.
Dryer vent periscope
Posted on May 21, 2011
How do I change a vent in the back of a dryer to the bottom?
Most new models have plates that can be removed so that you can vent to any side except the front. The bottom is considered a side. You need to get to the inside of the unit and then move the exhaust hose to the area that you want it to vent to. IT would be helpful if you post the make and model.
Dec 03, 2014 | Dryers
My dryer is not drying i noticed there was no air coming out the vent out side
disconnect the exhaust vent from the back of the dryer and see if you have any air coming out of the back of the dryer if you do you will most likely have to replace the exhaust vent line that goes from the back of your dryer to your outside vent. Blockages of lint build up over time and should be cleaned at least once every 6 months. If you find that you have no air coming out of the back of the dryer when you remove the vent line message me back for further diagnosis. I await your reply
Thank you
Rick
Oct 27, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
How do i change the high limit thermostat on a kenmore dryer # 72822
Unplug the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the back of the dryer. Loosen the retaining screw on the clamp connecting the vent to the dryer's exhaust port and slide the vent off of the port.
Remove the hex nuts holding the dryer's rear panel in place and slide the rear panel off to the side of the dryer. Locate the high-limit thermostat on the heating element housing on the right side of the dryer. The oval-shaped thermostat can be found a few inches from the bottom of the heating element housing.
Unplug the two thermostat wires by sliding them off of the thermostat's contact posts. Slide the old thermostat out of the socket on the heating element housing.
Mar 12, 2011 | Kenmore 72822Gas Dryer
Need to change vent from rear to left side
why don't you just go to home depot and buy a longer flex hose?mike
Feb 19, 2010 | Kenmore 64942 Electric Dryer
Cant locate vent exhaust
the vent come out at back or sometimes bottom side you cant miss it
Jun 21, 2009 | Kenmore 63942 Dryer
A sock fell into the lint resevoir; how do I remove it?
If your dryer is the model you have this listed under (lint filter on the top panel), then retrieving something stuck in the vent is pretty simple. Just follow these steps:
1. Unplug the dryer and remove the back panel. The dryer exhaust vent is located on the left hand side (as viewed from the rear).
2. Remove the screws that hold the vent in place and remove. NOTE: Make sure you remove the two screws located on the top panel as well. The entire exhaust vent will come out.
If this is not how your dryer is configured, please post back with your correct model number. If you have any questions, please let me know. I hope this helps you.
Mar 31, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Dryer will not come on. i changes all my fuses and got a voltage tester and all that is fine, where can i find out about checking any fuses on the dryer itself?
Check the thermal fuse on the dryer.
Remove the rear panel.
The thermal fuse is located on the exhaust vent.
It is about 1 and 1/2 inches long and 1/2 inch wide. It is white in color.
It is at the left side of the exhaust vent outlet.
Mar 09, 2009 | Whirlpool LER4634J Electric Dryer
Vent placement
Keep in mind, a new dryer at peak performance is only able to exhaust air in a "STRAIGHT" line 90 feet away. The more bends you add to the exhaust that are unnecassary, will decrease the performance of your dryer.
Please don't forget to rate "jsrock516's" solution, His is perfectly on point.
Feb 06, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
100 people viewed this question
Top Dryers Experts
