Question about JVC AV-56WP30 56" Rear Projection Television
Convergence can i do this with out the remote becuase i have tried to with a universal but can't change to the blue or yellow
  • plater Sep 23, 2008
    My JVC-56wp30 has had the convergence repaired 2 times and each time it has lasted about a year and then it needs another 3-4 hundred to repair it. I have the original remote and have followed the instructions to adjust it but it will not work. What is the part that the techs have been upgrading and replacing? Can I purchase it and change it myself or can I adjust something to get it back going?
  • Larry
    Larry Oct 25, 2008
    My JVC AV-56WP30 convergence + won't stay still, people have red eyes and out of focus. I have the original remote it forks fine. Thanks' Lar
The two convergence ICs labeled STK392-110 are bad . Likely the resistors that go with them one or more are bad too.
If you have patience can use a ohm meter, solder properly and have good vision. You can fix this problem .
Parts can be found at www.eletronix.com . Good luck, maicomasher
Posted on Dec 20, 2008
  • Larry
    Larry Dec 23, 2008
    Inside of your tv on the circuit board there is a bad resistor and IC part .STK392-110 .
  • 70 Answers
You can but you need a good universal remote not a cheap 20 dollar one look very hard online and you can find some that download via usb from your computer for pretty cheap. mine at best buy was 130.00 i got it online for just under 40.00 but i had to search does your tv not have an automatic convergence button on the front
Posted on Sep 21, 2008
Can a hitachi convergence be fixed without a remote? seems like red is adjustable, but cannot access the blue line with our universal remote
Ur universal remote was able to move - + from the convergence grid wright,it is a good remote.The tv convergence board is dead.The tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead too.These parts must be replaced on the tv convergence board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 19, 2010 | Hitachi 43FDX01B TV
MY TV NOW SHOW BLUE AND YELLOW AT THE TOP AND
i have a 52 in rca tv and i turned it on and now there is a blue and yellow stripe at the top and bottom of the tv. and the people have a blue shaddow around them ? how can i fix this?????
Aug 25, 2009 | Hitachi Televison & Video
Philips tv
the problem you are describing is your convergence ic's are bad you need to replace them both...you need 2-STK392-120's you can get replacements at this link i posted as well as picture installation instructions and free online tech support
http://servicemanuals.vstore.ca/
May 08, 2008 | Televison & Video
Convergence without a remote control
you will need the origional remote you can get one fast through this link just enter the model number www.replacementremotes.com
its normal after an IC change for the convergence to need adjusting, universal remotes can sometimes do it, but i have only seen that happen once or twice usually they wont have the right feature to adjust then save the settings.
Mar 29, 2008 | Toshiba 43H70 43" Rear Projection...
Convergence adjustment @ 52MH84
press mute on the remote then while pressing mute press menu on the set.then you navigate with the instructions below.
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Jan 21, 2008 | Televison & Video
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Tv problem
seems like your tv got convergence problem . try setting up the convergence , use remote . if it does not help you may need to change convergence ic * 2
Oct 01, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Convergence
Touch-up Convergence adjustments Enter the Digital Convergence Mode (DCM) by entering 0-6-2-5-9-7-(Status or Index) on the Remote control. The following menu will appear: Select an active channel or Aux Input. A signal must be applied to the set when performing convergence. If any Customer Adjustments need to be made, the Menu button can be used to toggle between the Customer Menu and DCM. The MPOSD ADJUST is used to center the Customer Convergence grid. A highlighted cross will appear along with the Convergence alignment grid. The highlighted cross should be centered onto the center of the Convergence grid. To perform a Touch Up Convergence, highlight SELECTION and press the right cursor button on the remote. The following menu will appear: Selections STORE, RESTORE FACTORY, and RESTORE DEFAULT are not shown after selecting SELECTION. Press the cursor down button on the Remote for these selections to appear. RESTORE FACTORY loads Convergence defaults from the Factory Loaded section of the Convergence Memory IC. RESTORE DEFAULT loads Convergence defaults from the sets software. To perform a Touch-up Convergence: 1. Enter the Convergence Mode and select RED TO GREEN or BLUE TO GREEN. Do not select GREEN (Green Geometry) without placing a Template over the screen. To perform Green Geometry, refer to the Complete in-depth Convergence. 2. Use the Cursor buttons on the Remote to Navigate from one adjustment point to another. Press the Status or Index button on the Remote to select ADJUST. Use the cursor buttons on the Remote to adjust the Red to Green or Blue to Green. Press the Status or Index button again to navigate to the next adjustment location. 3. After Convergence alignments are complete, press the Menu button on the Remote to return to the SELECTION menu. 4. Highlight the STORE selection and press the right cursor key on the Remote to save changes. 5. Use the GREEN TO RED or GREEN TO BLUE selections to perform convergence when the Green CRT has been replaced.
Aug 18, 2007 | Philips 60P8342 60" Rear Projection...
JVC AV-56WP30 56" Rear Projection Television Logo
67 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
