Question about Kitchen Ranges
The steam buddy cleaner has the water filler cap stuck so solid tight I cannot use it to put water in it as it has not been used for a while. However I don't know who the manufacturers are? can you help please?
RockyNR1
  • 324 Answers
SOURCE: instructions for a kirby steam cleaner
Take a look HERE. It should help
Good Luck
Rocky
Posted on Dec 05, 2008
  • 92 Answers
SOURCE: Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
Posted on Jul 29, 2009
  • 136 Answers
SOURCE: don't know how much water to use in Scunci Steam Cleaner
The little cup that comes with it to fill it has a line on it and says "220ml MAX". I would not recommend putting anything but water into it!
Posted on Aug 09, 2009
  • 4088 Answers
SOURCE: Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
Posted on Sep 09, 2009
SOURCE: safety cap on the Euro-Pro dexuxe steam cleaner style SC507H
if it is anything like mine...you push the cap down, give it a full turn & release. keep doing this (maybe 5 or more times, and eventually it will start unscrewing easily without needing to push down
Posted on Feb 28, 2011
Where can I purchase a safety filler cap?
See Google.
[PDF]steam cleaner - Pdfstream.manualsonline.com
pdfstream.manualsonline.com/.../e7f63cef-798e-41f3-bec7-5e43d5da5d...
When using your Steam Cleaner basic safety precautions should always be ... not screw the safety/filler cap onto the .... When using the Ultra Steam Shark II with.
Sep 29, 2015 | Shark Ultra Steam-blaster Hard Surface...
Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
Sep 08, 2007 | Euro-Pro Steam Generator EP8001 Iron
My Euro-Pro leaks steam at the filler cap. It is tightened down but still leaks. Have replaced the rubber ring in the cap but still leaks dangerous pressure steam.
take cap off remove gasket get clr calcium lime rust cleaner put cap in cup of clr give it 4 or 5 min remove rinse replace gasket, empty tank fill with distilled water not tap water no from now on use distilled water only.
Oct 18, 2014 | Vacuums
Cannot unscrew filler cap from steam cleaner SC 1.020
Get under it with something like a butter knife and lift with the knife while you turn it.
Mar 13, 2014 | Karcher Vacuums
Have a Salton EX 15 coffee Espresso maker and my espresso top dial (strength control) is now clicking versus smoothly turning and no water is now coming out. The froth stem is working fine. Also cant find...
The reason why the setting dial is clicking, because it's stuck on steam only and when you turn the dial to make the coffee it's grinding instead of turning smoothly. you need to remove full top cover. And to do so, you need to remove the two screws hidden under plastic caps next to opening where you add water for espresso or steam. Once the screws are out you can lift the top of slowly unlocking the corners.Tthe dialer knob stay on the top cover. Using a basic plier or locking plier turn the nozzle stem to unlock it from steam position...When you put it back together make sure it's back on steam not so tight and put cover and dialer setting at steam. put back the two screws and covers...Enjoy... from : jenlwe.thecustomeradvantage.com
Jan 05, 2011 | Coffee Makers & Espresso Machines
My floormate upper tank has a screw on filler cap nad the tank tank does not obviously come off the machine. The filer cap is under a hood and also cannot be used with iut removing the tank.I must not have...
Please let me know the model number from the data plate.
It is likely started with the letter "H", followed by at least for numbers.
It will allow me to post the User Manual to you.
Mar 12, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Its blowing oil out of the oil cap why would this be ?? also i bit of white smoke then came out the back
The oil level may be too high.
Is the filler cap tight?
blow-by in the cylinder piston rign area. A wet test of engine compression will detect this.
A bad had gasket. Engine will be over heating as water is being used up during combustion.
Bad head gasket. Could explain white smoke in exhaust.
If the engine is overheating I would be suspecting a problem in the head area.
Good Luck. SnugglePants
Oct 26, 2009 | 1988 Mitsubishi Galant
What type of oil is needed in my FXSTD softail and how many quarts? I did not get the owners manual with the bike and would like to change the oil myself. Thanks Al
hi buddy i found the correct oil SILKOLENE V-TWIN 20W-50 add 3,3litre of oil if changing oil filter aswell if not add 3.0litre just run the bike for 10 mins to get oil warm drop the plug out underneith the engine let it drain put the plug back in unscrew filler cap add oil once filled retighten filler plug run for 5 mins recheck oil / unscrew oil filter aply oil to seal on oilfilter and retighten on hand tight hope this helped buddy
Sep 17, 2009 | 2003 Harley Davidson FXST Softail Standard
Sep 09, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Screw top not coming off
If you look under the black plastic cap (between the bottom lip of the cap and the yellow steamer body) you should see a circular hole in the pressure valve that the plastic cap is attached to. I used a flat blade screwdriver and a hammer to tap it anti-clockwise, the whole filler cap could then be removed.
Putting sone lubricant (plumbers lube or vaseline) stopped this happening again.
By the way, you just need to tighten the filler cap finger tight.
Hope this helps.
Apr 02, 2009 | Tristar SB Steam Buggy Vacuum
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
