Question about JVC AV-65WP94 65" Rear Projection Television
Double image from red bulb - JVC AV-65WP94 65" Rear Projection Television
    Genius:
  • 1,156 Answers
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synchronizing.
RP TV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
Posted on May 21, 2011
Have a 46f500 hitachi projection television. Started out with a blue reversed arc hanging down on upper right. Now images are not focused, and red, blue and green are layered. Double images. I looked...
It is a convergence problem and set uses two of the STK-392-150 CHIPS. Both will have to be replaced and the set adjusted.
for more information let me know if you can solder and your skill levels.
SD TECH
Jan 11, 2011 | Hitachi 46F500 46" Rear Projection...
Hello my tv is giving me a double image with red shadows on the right side of the pics. I think on of the bulbs is going out is this possible and how do I check to see which one it is?
The problem is not usually the bulb but the convergence IC's on the convergence board. When you see color shadows or if your TV look like you are looking at a 3D image you either have one or both Convergence IC's out. If you are handy with a soldering gun and a voltage meter you can do this repair yourself otherwise you will have to call a technician. You will also have to check a couple of resistors and fuses.
Dec 15, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a philips projection tv, there is a green hald circle at the bottom of the screen also the picture has double images and very yellow and red. I just bought this from someone who keeps telling me its...
It sounds like multiple problems. First of all these sets are famous for bad coolant between the tubes and lenses causing the picture to be degraded causing the foggy picture. The fluid can be changed to clear up the halo's. The double images are convergence issues. Most likely both convergence amps need to be replaced. I hate to say it but it sounds like you got a money pit. Good luck. Thanks for using fixya.
Dec 21, 2009 | Philips Televison & Video
The screen suddenly turned red with dual lines of red and blue. Almost a double image?? Can this be corrected or fixed??
My name is Charles and I will be assisting you with your issue.
Have you changed the source input or the bulb recently?
When did this issue start and is it there always or does it change?
Nov 01, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Double image with red and green outline on image
Unit will require the 2 STK392-110 convergence amps to be replaced along with a couple of low ohm resistors.
Jan 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Double image
yes you just need two ICs
Jul 12, 2008 | Akai PTH5498 54" Rear Projection...
Double images
You need to replace both convergence ICs they are STK392-560 you can get replacement ICs at the following link and they provide free installation instructions with pictures so you can install them yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | Sony KP-65WS500 65" Rear Projection...
It needsre- align the projection bulbs to get rid of the double image
More than adjustment...needs convergence circuit IC's replaced.
STK392-110 subs to upgrade STK394-160E Hitachi CZ 01341..
then use magic focus........................................T.
Dec 17, 2007 | Hitachi 43UWX10B 43" Rear Projection...
JVC AV-65WP94 65" Rear Projection Television Logo
83 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
