Question about Mavic Cycling
I have been having issues with my real wheel on my bicycle. I have Mavic Ksyrium Equipe wheels, and the rear wheel seems to be flexing too much under loads (i.e. sprinting, climbing, descending, and cornering). At first it manifested just as an annoying thumping noise as the wheel rubber the brakes, but now the rear wheel will feel wobbly and loose (much like when you get a rear wheel flat). I've taking my bike into my local shop, and they can't seem to figure out the problem. I am a larger rider (6''0", 250 lbs) and I'm wondering if this might have an effect on the wheels. However, I've had them since I first bought the bike (9000 miles). I had the wheel rebuilt two years ago, when the rim cracked. But other than that, this is a brand new problem.
    Brigadier General:
  • 8,546 Answers
It's hard to believe a shop can't deal with what sounds like loosening spokes. OTOH, we Clydesdales are tougher on wheels than the lil guys. I used to break a lot of spokes under high torque demands, especially on several sets of Spinergy Spox wheels, then I bought a Park spoke tension gauge and meticulously trued and tensioned all the wheels on all my bikes. Haven't had a spoke issue since then.
Or you could get an old set of Spinergy Rev-X like I did a long time ago before I figured out the tension thing. If you can break or bend them you are not human.
Posted on May 22, 2011
How do I replace a Tracomp spoke on a Mavis Ksyrium SLR rear wheel? Can't work out how to release the hub end.
I believe you'll have to undo the spoke at the rim end (Mavic uses a torx style head on the nipple). With the hub end of the spoke, looks like a ball but with two flat sides. When the spoke is tensioned it seats the ball end into the straight pull flange. This style is used in pretty much all of Mavic's high end wheel sets (Road or Mountain). Some have a plastic clip-on type cover. This can be removed with a flat head screwdriver. Good Luck!
Oct 13, 2013 | Mavic Ksyrium SLR Rear Wheel/Tire
Broke spoke on mavic kyserium sl can't ride bike, miles from home
being a french bike I don't know who can get you a replacement , but if its just a spoke or two,, wind the broken ones around so they don't rub on the fork or frame, and I'll keep looking , so check back, wow those are expensive,, heres a link
http://www.amazon.com/Mavic-Ksyrium-SL-Bicycle-Rim/dp/B0034L0872 Is it the front or rear ? heres a rebuilt one for less http://www.competitivecyclist.com/product-components/2011-mavic-ksyrium-sl3espremium-wheel-rebuild-4051.1849.1.html
Jul 15, 2011 | Mavic Cycling
Wheel does not stay true
Check if your spoke are tight enought, sometimes if the spokes are loosen the wheels will bent really easy.
May 18, 2010 | Mavic Ksyrium Elite Wheelset
Cant put my mavic back together properly
It sounds like you lost the washer that sits between the bearing in the nose and the freehub bearing. If you lose that washer, when you re-tighten the axle, the two bearings will bind and prevent the freewheel from spinning easily.
Take your freehub off again and see if that washer is there. If it isn't, you'll have to get a new one and replace it. It's easy to lose that thing if you don't know it's there when you take the wheel apart, because it'll just fall out.
When I reassemble those wheels. I thread the drive-side axle through the freehub body, then place the washer over the axle on the inside of the bearing, then thread the axle through the nose.
Also note that if your freehub seemed loose, it probably needs to be replaced. The FTS-L freehub body used on the Ksyrium wheels uses a nylon bushing as the friction interface to the nose, and this bushing wears down over time even with good lubrication.
Feb 10, 2010 | Mavic Ksyrium Elite Wheelset
HELLO, I HAVE A DURA ACE 7900 MODEL CASSETTE AND WOULD LIKE TO PUT IT ON A KSYRIUM SL RIM, DO I HAVE TO PUT THE SPACER ON IT BEFORE THE WHOLE CASSETTE GOES ON? THE CASSETTE IS A 12-25 GEAR.
In my experience with Shimano cassettes on Mavic wheels, the answer is "yes" but i had a mountain wheel and cassette. The only way to know is to put it on and see if there is slop in the fitment. If there is, then you have your answer. i also had this problem with Mavic: i had to adjust the high and low settings on my rear derailleur because of the awkward spacing of the Mavic freehub. Just something you should be aware of in case you have difficulty with shifting after the install. By the way - although they are inferior cassettes, SRAM cassettes seem to fit Mavic freehubs better.
Regards,
matt
Sep 14, 2009 | Cannondale Cycling
Squealing noise for no apparent reason rear wheel when freewheeling
Could be a bearing..
If there is a grease fitting - try pumping some grease into it..
Other than that - try some penetrating oil or white lithium grease where the bearing are..
Jul 09, 2009 | Mavic Ksyrium Elite Wheelset
Noisy Rear Mavic Ksyrium Hub
Sounds like a road wheel with a worn FTS-L freehub body. You'll need to have it replaced.
What happens is that the nylon bushing wears, causing there to be play between the freehub and the nose of the wheel. Once there is enough play, the freehub can actually vibrate against the nose, causing noise and friction - which is why you see the chain slacken. This is commonly called the "squeal of death," meaning it is an indication that the freehub body is "dead."
A new FTS-L freehub body should be about $50-60 and shop shouldn't charge more than about $20 to change it out. Just be sure to tell the shop one very important thing:
"Do not lose the metal washer that sits on the axle between the outer bearing of the freehub body and the outer bearing of the nose of the wheel!"
This is so incredibly important - but time and time again, shop mechanics will lose this washer before they reassemble the wheel, causing a series of nightmares with the wheel.
Jun 09, 2009 | Mavic Ksyrium Elite Wheelset
Cycling Logo
182 people viewed this question
Top Mavic Cycling Experts
Eric Hidle
Level 1 Expert
Michial Gueffroy
numbers819
Level 1 Expert
Are you a Mavic Cycling Expert? Answer questions, earn points and help others
