Question about Troy Bilt 175HP Manual 42" Riding Mower
Troy-bilt model 13AN77TG766 wont go forward or backward. Belts seem to be moving fine. Please help, unable to find manual online.
    President:
  • Troy Master
  • 1,545 Answers
The manual probably won't be of much help with this problem. Your transaxle may have seized up or failed due to the introduction of water into it. A lot of riders have had this problem, especially the ones with the DANA manufactured transaxle. I hope this is not your problem, and that the problem is in your shifter linkage between the lever and the transmission.
I am continuing to look for the manual. In the meanwhile, here is your complete machine with All parts, diagrams, breakdowns and part costs included. Hope this helps. It is sometimes tough to locate manuals as you have found.
http://www.partstree.com/parts/?lc=Troy-Bilt&mn=13AN77TG766+Pony+%282006%29
Posted on May 21, 2011
Belt diagram for Troy bolt model 13an77tg766
Troy-Bilt might be able to supply a diagram.
Jul 16, 2017 | Troy Garden
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I bought a riding mower md # 13an77tg766 i replaced the drive belt but it still wont move in first or second and 3rd just barley i dont know what else to try i have to be in 4th gear just to get it...
Tried to look up your model, but you must have not gotten all the numbers, it doesnt come up.
There should be 2 drive belts on it tho, and you should replace both, not just one.
Sep 04, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
T bilt riding mower deck
I think this is what you are looking for:
https://www.dixiesales.com/ipl/339/13an77tg766.pdf
May 07, 2010 | Troy-Bilt Troybilt Tomahawk I Drive Belt...
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
Belt comes off the deck on my Troy-bilt model number 13an77tg766
If your going through belts that often you better order some spindle bearings and have them rebuilt,excess play in your deck spindles can cause you a lot of money repacing belts.
Aug 07, 2009 | Garden
I need to replace the transmission drive belt and need instructions
There's actually a Troy-Bilt Pony riding lawn mower as well.  If yours is like ours, a model 13AN77TG766 [URL:http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02243a.pdf], it doesn't actually have gears but rather a variable-speed pulley.  The lever on the dashboard actually controls how high the brake pedal will go, while the brake pedal controls the position of the variable-speed pulley, which controls the effective gearing ratio.  That's how it can go at any speed with the engine still going at the same rate and without having to disengage a clutch.
So perhaps your mower is engaging the parking brake too early (page 17 of our manual).  The other thing I can think of is grass in the variable-speed pulley.  To check that, remove the spark plug and the battery (7/16-inch socket).  Then move the shift lever through its full range and check the shaft of the variable-speed pulley (part 63 on page 34) for debris, both above and below the loose plate thingy.  (You should be able to turn it quite easily if you put the forward/reverse lever in neutral.)
Hope that helps!
Jun 01, 2009 | Troy-Bilt Pony Garden Tiller
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt 175HP Manual 42" Riding Mower Logo
1,474 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
