Question about Frigidaire 22.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White
My Frigidaire fridge model # FRS6LF7FW3 has stopped cooling and freezing, water has leaked out and everything has/is melting in the freezer. The light bulbs work but the freezer and fridge temp window lights do not. Any idea on what could be wrong with it? Thanks.
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 22, 2011
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Frs26zsh is having wter leaking and freezing at bottom of freezer what can i do
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Feb 06, 2011 | Frigidaire Refrigerators
Frigidaire FRS26ZNH frig is freezing water in the bottom of the freezer and is leaking water onto the floor. i have looked for a stopped up drain plug or hole with no success. please help. john
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Aug 30, 2010 | Frigidaire Refrigerators
Water freezes around coils and stops fan motor from cooling the fridge, freezer continues to cool. Have had three repair people out, one replaced the moter the other replaced the heater and one said the...
Check for a leak in the water dispensing tube for the ice maker. If there is a leak you can use plumbers tape to seal it off.
Otherwise, tell me more about where your Fridge sits? What's around it?
Mar 20, 2010 | GE GDS18SBPLSS Bottom Freezer Refrigerator
RED TEMP WARNING LIGHT ON MOTOR RUNNING
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Nov 17, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Frigidaire 22.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White Logo
238 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
