Question about Craftsman 25cc Gas Line Trimmer
Pull cord on weed eater won't go back in - Craftsman 25cc Gas Line Trimmer
    President:
  • Craftsman Master
  • 1,545 Answers
You can attempt to diagnose and/or repair this problem by taking the following steps. This involves some work so if you aren't ready for that activity, then read no further.
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 (Star bit or Torx head) screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a hammer and a dull flat-blade chisel or a small piece of wood unless there are bolts. then use a wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers and a good flat-blade screwdriver. Post back if needed.
Posted on May 21, 2011
  • 92 Answers
Well that is the starter pully spring, so you need the starter pully kit.which can be found on any hardware store in gardening department like ,homedepot,lowes,etc
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
May 10, 2014 | Craftsman Garden
Pull on cord for weed eater y 28 yard machine hard to pull how do i repair it
Hmmmmm. The question is why does it pull hard to begin with? Did the pull cord get wrapped around the pulley in an awkward manner or is the machine seized up? If it's not to difficult, pull the muffler off the machine and look at the piston. If it looks scored (lines up and down the piston through the rings) It's shot and probably not worth fixing. But, If everything looks good, then I'd pull the starter assembly off and see if there's something going on there that's doesn't look right.
Sep 23, 2012 | Garden
My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
Mar 25, 2012 | Toro& Electric String Trimmer
How to change the fuel filter on a Weed Eater Feather Lite FX265Xtreme 25cc. The weed eater stars but won't run.
Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
Oct 12, 2011 | Husqvarna Forest & Garden 125c 17"...
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a WEED Eater Model SST 45. I left the switch on all winter and now it won't start. What is wrong?
If it is a pull start, leaving the switch on did no damage to the weed eater.
Gary
Jun 29, 2011 | Garden
Craftsman 25cc Gas Line Trimmer Logo
714 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
