Question about DeLonghi DCM485 Coffee Maker
How do I program my DeLonghi DCM 485? - DeLonghi DCM485 Coffee Maker
  • DeLonghi Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
Posted on May 21, 2011
Will a john deere snowblowerfrom a 445 fit on a 485 john deere?
You will need longer hydraulic hoses because the ports are on the opposite side of the 485 but will work. If the 485 has mower deck it will have to be removed or buy a quick hitch to set the blower back a little further. Go for it....
May 29, 2017 | John Deere Garden
Does dlink dcm-604 broadband cable modem incorporate a NAThardware firewall?
it does have a built in firewall.
http://www.dlink.com.sg/Starhub/downloads/DCM-604Manual.pdf
page 19.
Mar 06, 2012 | D-Link Computers & Internet
Where is the mp3 plug in for a denon DCM-280
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Denon-DCM-280-CD-Players-review-manual/id/363ci871/t/1-2/
It's capable of playing MP3's right out of the box. See page 18.
Feb 21, 2011 | Denon DCM-280 5-Disc CD Changer
How can i upgrade the firmware on dcm 201 cable modem
The product currently has not firmware updates available
http://www.dlink.com/products/?pid=DCM-201&tab=3
I will get you an update when its available
Dec 25, 2010 | D-Link DCM 201 (DCM-201) Modem
Need D-Link DCM 200 Modem driver
You should be able to find your drivers at this address:
http://www.dlink.com/products/?pid=DCM-200&tab=3
You will need to click on your country, as this is a discontinued product.
Hope that helped :)
Oct 17, 2010 | D-Link DCM 200 (DCM-200) Modem
I have repaired two units (DCM 485) by jumping one of the two thermofuse which failed. I assume this fuse is redundant give there is a second such fuse in-line with the heating element and a thermostatic...
You should never jumper a thermofuse no matter how convenient it can seem. All your customers have to do is forget once and you are liable. If you are a repair person then find the correct fuse or replace the unit. Safety is above all in every case.
Feb 07, 2010 | DeLonghi DCM485 Coffee Maker
485 to 232 conversion
<Dear Sir can ADAM-4520 transparently converts 485 to 232 as it does for 232 to 485>
Yebo, yes it can. Thanks for calling me sir.
Jun 27, 2008 | Advantech ADAM-4520 (ADAM-4520-D2) Serial...
Only two lights on DCM 200
have you reset the modem by holding in the buttom either under neath or at the back of it for at least 20 seconds try that
Dec 19, 2007 | D-Link DCM 200 (DCM-200) Modem
Delonghi dcm 485 power on but will not brew
THANKS "Guest" - you just saved me $100 !
I had already bought a new coffee maker (Krups) when I came across your post.  The thermal fuses (there are two of them) are indeed hidden - they are right underneath the metal braces/clamps that push them against the heating element that they are meant to monitor.  If you take off these clamps and pull back the white insulation you can easily replace the fuse(s).  What you need is:
- volt meter
- needle-nose pliers
- Radio Shack thermal fuse 228C (catalog #270-1321) - these are rated at the same temperature and look fairly identical.  They cost $1.69 at your local Radio Shack
You do NOT need a soldering iron.  So: - take off the bottom of the coffee maker - take off the clamp(s) and pull back insulation. - put your volt meter on either side of the fuse and check for continuity.  In my case, one had no resistance (good) and the other had no connection (bad). - take your needle nose and pry open the clips on the end of the wires that connect to the bad fuse ... put in the new fuse (make sure the polarity matches ... just in case) and scrunch the clips together again - replace everything
In order to make this easy to do, I disconnected the water intake/outtake and also removed the two screws holding the whole heating assembly.  Made it a lot easier
Aug 19, 2007 | DeLonghi DCM485 Coffee Maker
DeLonghi DCM485 Coffee Maker Logo
205 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
