Question about Canon Pixma MP500 All-In-One InkJet Printer
Incomplete Scanning I'm trying to scan an 8.5 x 11 sheet of music as a pdf. The first page scanned just fine. The second page scans only 3 inches in the middle of the page. It's being cropped for some reason. Any ideas on how to fix it? Thanks
  • Anonymous Sep 02, 2008
    ahhhh! same problem scanning music. first sheet is fine, second scans a couple inches of the top and a couple from the bottom, creating two pdf's..
No, your paper hasn't slipped. This is an unresolved bug in the MP500 where it does not detect the size of what you are scanning. Luckily, this appears to only be a problem when attempting to scan from the machine itself. If you use the MPNavigator Software and MANUALLY choose the size of the document you are scanning, it should work. This caused me HOURS of frustration before I found the solution. Good luck to you!
Posted on Sep 02, 2008
The paper may have slipped of the scanning area
Posted on Aug 26, 2008
Can i get front and back side of pages scanned at a time, if yes then how? how can i scan a book of 50 pages by giving one command?
What scanning software are you using? In Adobe Acrobat Professional 9, you can set up different scan profiles, including duplex scanning. The sheet feeder holds up to 50 pages; you just tell the software to make all pages one pdf.
Dec 02, 2010 | Kodak i1220 Pass-Through Scanner
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
HP Laserjet M1522nf Multi page scanning problem
Check this thread in HP forums:
Second Page Scan is Garbled on HP1522nf
Download the file attached to LARS post halfway down the page and follow his instructions on how to unzip and install it.
Hope this helps.
Sep 11, 2009 | Office Equipment & Supplies
Scanning files to large
It's the resolution you are using to scan. Try a lower setting. for documents, 150-200 dpi is fine. That will produce smaller files.
Aug 25, 2009 | Dell 922 All-In-One InkJet Printer
Real Slow scanning?
You can try to reduce the resolution, but my own experience scanning to pdf files leads me to believe that your machine is functioning ok. I have 1.5 GB RAM and a dual-core processor that is much faster than the P3, and when I run several documents through, it takes a awhile to scan them
Aug 17, 2009 | HP LaserJet M1522nf Multifunction Printer...
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
S. Mohan, Chennai, India
Apr 16, 2009 | Canon DR-5010C Scanner
Kodak i260 Scanner
This is practically impossible. This can happen only when the file is over written! Check your software settings. May be you have selected 'multipage' option. Try scanning one page and two pages (same sheet). If the file size is different, then it means two files are scanned.
Reload your Driver and check your scanning software. I am assuming you are usning winXP/Win 2000.
S. Mohan
Jul 30, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Jul 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Scanning problem to .pdf
Have you tried FoxIt Reader?
plz re install adob but before that plz un stall it from the control panel
Mar 04, 2008 | Computers & Internet
Scanning sheet music
Scan all pages with GrayScal Single Page JPEG and then convert them to Multipage PDF.
Jan 22, 2008 | Canon CanoScan 8000F Flatbed Scanner
Canon Pixma MP500 All-In-One InkJet Printer Logo
265 people viewed this question
old marine
old marine
