Question about E-Machines T3418 PC Desktop
What te bios password for emachine. I want to enable my ethannet which in BIOS set up. But I do not now the password of BIOS. I have not set up myself.
    Problem Solver:
  • 12 Answers
How to reset you bios password.
Step 1: Power off you computer and unplug power cable.
Step 2: Open the computer case so that you can see the motherboard.
Step 3: Find the 3 pin jumper on your motherboard and put it on the other pin. Ex: If it is on 2 and 3 you will want to put it on 1 and 2.
Step 4: Plug your power cable back into you computer and turn it on. (Note: Your computer will not load you operating system.)
Step 5: Shutdown your computer and unplug it again.
Step 6: Put the jumper back into it original position.
Step 7: Plug your power cable back in and turn your computer on.
Now you bios password should be reset.
To enter the bios press the the F2 or Del key when your computer is turning on. (Note: This varies for different manufacturers.)
I hope that this helps you!
HelpDeskMan
Posted on May 21, 2011
  • HelpDeskMan
    HelpDeskMan May 25, 2011
    Please rate this post and/or leave a comment. Thank you
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
Bios password lost how can i reset it
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Dec 11, 2013 | Acer eMachines 520-2890 Notebook
I changed my hard drive and now it wants a built in hdd1 password and l dont have a clue
hii
To create an HDD password you have to enter your BIOS
At startup press tab button to enter your BIOS ,ther you will BIOS setting
password enable.
enter your password and enable it.
Thanks
Aug 23, 2011 | Toshiba Computers & Internet
Please i need bios password code for eMachines eMD725 Phoenix with 07668 systems. when i want to reinstall the operating system is always constrained by the bios password code.
Hi, The BIOS password is a password that you would have set on the laptop to protect the hard drive and during the installation of Windows you would need to key in the BIOS password so that you can go ahead with the installation of the Windows.If incase you have forgot the BIOS password please contact eMachines if the laptop is covered by warranty so that they would be able to assist you remove the password on the computer.If the warranty has expired then you would need to contact a local technician at your place who would assist you reset the BIOS password which would require opening the case of the laptop and reseting certain cables within the laptop. Thank you for your time and best wishes for your effort.
Jan 12, 2011 | eMachines eMD620-5133 Notebook
Each time i try to enter biou setup i get the massage bious guardian enable, how do i disable this thanks
Look around in your BIOS for a tab that says "Security Settings" then look for the setting to enable or disabled BIOS Guard™
Oct 17, 2010 | E-Machines eMachines Desktop PC
Password bios emachin
That is going to depend on what it was set to. There is no factory password for the Bios on these computers. If you have forgotten the password you will need to reset the Bios using the jumper on the mother board. If you don't have your book on the motherboard you will need to go to the eMachine website and look up the down load of the book for your specific model.
Oct 12, 2010 | E-Machines (308714) Motherboard
EMACHINES T3522 Message "ENTER PASSWORD TO UNLOCK SYSTEM" ON STARTUP
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3522 Chat with a tech. I think a system password has been set by someone. Most probably a bios / HDD password. So you need to know that to boot. Bios reset may do the trick (by removing cmos battery). But you have to set the settings back to normal in BIOS. But if you have encrypted data you may harm them. (Rarely).
May 29, 2010 | eMachines T3604 PC Desktop
Password for entring my bios
BIOS Passwords Basic settings on your computer such as how many and what kinds of disk drives you have which one are enabled and which are disabled and which ones are used for booting are held in a CMOS chip on the mother board. A tiny battery keeps this chip always running so that whenever you turn your computer off, it still remembers its instructions. A common method of entering the BIOS is pressing the Del key at Bootup other common methods are Ctrl +Alt +Esc and Ctrl + Esc. Most computers have a BIOS which can be configured to ask for a password as soon as the computer is switched on. If the Ask Password option is enabled then as soon as the PC is switched on a Dialog box welcomes you and asks you for the password. You cannot override this and there is no way of disabling this because to enter the BIOS you need to know the BIOS password. So what do you do? Disable it. Now to Disable the BIOS password you need to enter the BIOS. But as soon as you enter the BIOS the BIOS asks for a password. Now the most common method of overriding this password prompt is by trying out the default BIOS passwords. Some common passwords are: Lkwpeter j262 AWARD_SW AWARD_PW Biostar Many BIOS also have their default password that can be tried. "j262" opens most versions of Award BIOS it works about 80% of the time. "AWARD_SW" and "AWARD_PW" work on some computers as well, but much less often. In some BIOS shift+s y x z also works. The best way to find out the default passwords of various BIOS is to search at http://astalavista.box.sk which is the best search engine for security related matter Well if the default passwords did not work them get ready for some serious Hacking stuff. Now as the default BIOS password did not work we will try to reset the BIOS to its default settings so that it asks for no password at all. So to do following: First you have to open the computer and then look for a round lithium battery, it probably looks like a silver coin. So remove the battery and after 30 seconds or so put it back. Some computers may also require you to reset the jumper, so look for a 3-pin jumper and reset it. For example, on most machines you will find a three-pin device with pins one and two jumpered. If you move the jumper to pins two and three and leave it there for over five seconds, it will reset the CMOS. When you boot the machine some BIOS may give an error saying that the BIOS was reset or tampered with, but that is not such a big problem
Apr 30, 2008 | Acer Aspire 5610-4648 Notebook
E-Machines T3418 PC Desktop Logo
248 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
