Question about Packard Bell (181368) Motherboard
I need a manual for the motherboard mcp73pvt, as im not sure if the cmos jumper has been touched and i cant see the position its ment to be in
  • Packard Bell Master
  • 27,725 Answers
Http://www.brothersoft.com/downloads/computer-manuals.html
you will have to type in the motherboard in the top search tab
or
http://help-site.com/c.m/
hope this helps
Posted on May 22, 2011
Motherboard Jumpers
The jumpers are just for operational or resetting the CMOS, it's either 1 or 2 positions only typically. Those other jumpers you're talking about are for settings, they typically have letters indicating where they should go, I'm sure you can find where you should put them on the ASUS website if not google it. Keyboard detection might be an issue with your bios settings, make sure you have Plug & Play OS enabled or manually set it to work with USB.
Aug 04, 2012 | ASUSTeK COMPUTER Asus P5gc-mx/1333...
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
Hi, I messed up my BIOS by trying to update it... I got an asus p4b533 and cant find how to do a CMOS reset. I read about shortening two bumps because this board obviously has no jumpers to reset CMOS....
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine.
Hope this helps
Jan 16, 2011 | ASUS P4B533-VM Motherboard
Dell inspiron 1545 has authentication system password ..tried removing battery cannot get pass it
The aim is to reset the BIOS so that data concerning passwords are cleared out. This is done by moving a jumper on the motherboard.( The biggest challenge is to find it).
Note that: This procedure also resets the BIOS settings. If you have made changes, this manipulation will reset these features to default.
  • Step 1: Turn off your PC and unplug the power cable and open your system unit. Touch the chassis of the casing with a metallic object to discharge static electricity.
  • Step 2: Check the documentation for your motherboard to locate the position of the jumper, that reset the BIOS. If you don't have any manual, look on your motherboard one of the following tag: CLR BIOS, CLEAR BIOS, CLR CMOS, CLEAR CMOS, RESET BIOS or RESET CMOS. It is usually near the CMOS battery on the motherboard.
  • Step 3: Find the jumper on your motherboard reset it. It is usually close to the battery.
If the jumper is on 3-connector pins, place it on the middle and the initially uncovered pins.
Wait for some time and put the jumper in its original position (PIN1-PIN2).
If the jumper is on a 2-connector pins and that it holds on a single pin, place it on both, wait one second and then return it to its original position.
  • Step 4: Power up and start your PC: the password has disappeared.
Dec 04, 2010 | Dell Inspiron 1545 Notebook
Cant enter bios
Clear the motherboards CMOS. Be sure to unplug the computer's power cable from the computer, move the CMOS jumper to the "clear" position or remove the battery for a few minutes. Reposition the CMOS jumper and power up the system.
Jun 17, 2010 | Acer Aspire 9810 Notebook
My board will power up but i cant get any video dont know where to srt jumpers
FOr reset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 10, 2009 | PC Chips P23G Motherboard
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
I have a battery dead on the mobo. changed it, now i cant get past the cmos p-word. tried pulling the batt, and jumpers. nothing works.
Make sure power is off and unpluged. Pull the CMOS battery out and get a screw driver. Then touch the two battery tabs where the cmos battery goes for about 1 minute or so. This should reset the cmos.
Aug 05, 2009 | VIA : EPIA-M10000 C3 1GHz...
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Toshiba Protege 2000 Lost BIOS Password
if you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
Jun 24, 2008 | Computers & Internet
Packard Bell (181368) Motherboard Logo
648 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
