Question about Garden
Describe your family ybsxs 1901vc spark plug gap Problem Just need to know the gap on plug
5 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: need to know simplicity snowblower gap setting
.030 (THIRTY THOUSANDTHS)
Posted on Oct 11, 2009
harlan301
  • 205 Answers
SOURCE: Need to know what the right gap setting is for the
gap at 30, RJ17LM
Posted on Oct 14, 2009
Testimonial: "Recieved the answer in minutes, thanks for the help as I could not remember the gap and the missus took the manual."
  • 144 Answers
SOURCE: need to know gap for
Going with the shop manuals you should be alright with .25" to 30", without knowing what kind of machine you have. Hope this helps. Best regards and good luck.
Posted on Jan 27, 2011
  • 640 Answers
SOURCE: need to know what the
Generally the spark plugs for mowers come pre-gapped. I use to measure but they were spot on, so now I just do eyeball comparison from the old to the new one, just to check.
Posted on Jul 19, 2011
How to change spark plugs in a 2004 suzuki forenza?
change spark plugs in a 2004 suzuki forenza? google that
Jun 01, 2014 | 2004 Suzuki Forenza
What is the correct gap setting for a Champion RJ2YLE spark plug used in a Toro Lawn mower?
Briggs & Stratton Part Number 799876 replaces Champion plug RJ2YLE. For use in Quantum Series 625, 675, and 725 engines built after Date Code 110701xx. The gap for this spark plug should be set to .020". This spark plug should not be used with Quantum Series 625, 675, and 725 engines built before Date Code 110701xx, or any other L-head engine family.
Apr 20, 2013 | Toro Garden
I have a old yard machine self propelled lawn mower 6.25 HP 21" cut briggs & stration eng. Family YBSXS 1901VC 27446 EPA phase 1. I need the cable that goes from the saftey bar to the gas...
I have found OEM part number 746-0552 on Ebay. This is for older units, say 1997 on. The cable is 49" in length. Here is a link to ALL the MTD brake cables on Ebay.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=MTD+brake+cable&_sacat=See-All-Categories
Yours is the MTD-White Outdoor Push Mower Brake Cable. # 746-0552.
We call this the deadman/brake cable. It allows a small brake pad to rub against the flywheel on the top of the engine while at the same time actuating a switch which shorts out the ignition current to the spark plug. An interesting and much needed device, right! Good luck. Hope this helps.
Jun 12, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
I recently got a green Craftsman with yellow writing "Craftsman" and ("22" Mulcher") I didn't know where to look for the model number. I found a family "YBSXS.1901VC" then "274466" it also said not legal...
You need to take the mower into a SEARS authorized store and have them show you the code meanings. Craftsman has changed a lot of their codes so for the first time this is the only way.
Sep 11, 2010 | Craftsman Garden
Spark plug gap size 2000 ford escort sedan inline 4
LOOK UNDER THE HOOD, SEARCH AROUND AND YOU WILL SEE A WHITE STICKER WITH THE ENGINE FAMILY/DISPLACEMENT AND ON THE BOTTOM OF THE STICKER THE MANUFACTURER GIVES YOU THE SPARK PLUG GAP. HOPE THIS HELPS. LET ME KNOW. GOOD LUCK
Apr 30, 2009 | Ford Escort Cars & Trucks
Spark plug gap
hi kathy. this is an easy one. first of all you will need a spark plug gapping tool, about a dollar at any auto parts store. Your chain saw most likely calls for PLUG TYPE: Champion CJ6 SPARK PLUG GAP: 0.025 in. (0.63 mm).
Here is the website of a short video to show you exactly how to gap the spark plug. write back if you need any more info.
www.expertvillage.com/video/6078_spark-plugs-gap.htm
Feb 07, 2009 | Homelite ZR10926 16 Chain Saw
Proper gap of the spark plugs
0.8 mm or 0.031"
Use Nippondenso # K16R-U or NGK # BKR5EYA
Oct 30, 2008 | 1998 Toyota Tacoma
Garden Logo
233 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
