Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Installation of lid seal - Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
    Scholar:
  • Saniflo Expert
  • 115 Answers
Typically the lid seal has an opening all around the center and it must face up and fit inside the lid, once is fitted inside the lid cover, lubricate the bottom of the lid seal with soapy water and place it on top of the pump casing. Then apply pressure at the side tabs to snap the lid back in place, note that you may have to use a big C-Clamp to be able to put the lid back on.
Posted on Jul 13, 2011
Where can I buy or order the seal for the lid?
Go to Goodwill or thrift store and buy a cheap lid and replace your seal with the one from that lid.
Dec 18, 2015 | Crock Pots & Slow Cookers
I need top cover for my humidifier part number 324866-301 does anyone know where I can find one?
Shop for Humidifiers' top cover on Google
CPAP.com - H4i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../resmed-h4i-heated-humidifier-top-cover-seal.html
People Who Bought H4i™ Heated Humidifier Top Cover Lid and Seal Also Bought. ... This is the plastic cover used with the Resmed Humidiare H4i Heated Humidifier. ... People Who Viewed H4i™ Heated Humidifier Top Cover Lid and Seal Also Viewed.
HumidAire 3i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../H3i-Heated-Humidifier-Top-Cover-and-Seal.html
This is the plastic cover used with the Resmed H3i Heated Humidifier. It also includes the plastic gasket below the tube connector.
Sep 29, 2015 | Humidifiers
My 97 honda civic has been in an accident before now my trunk doesn't close completely and water gets in my trunk how do I fix that
The fix depends on what was bent - the deck lid or the back of the car. To find out, clean the rubber seal with brake fluid on a rag, then dry the seal with another clean rag. Put a small amount of motor oil on your finger tip and put a small line of oil on the top of the seal, making sure you have enough oil on the seal to wet it all the length of the seal.
Now close the deck lid GENTLY. Open the lid and inspect the surface of the lid that contacted the seal, as well as the seal. The area of the lid that is dry is where the lid and seal are not contacting.
If you cannot determine where there is oil or not, you can try putting a small amount of fine ground dirt on top of the oil before closing the lid. If you can see bends in the deck lid surface, replacing the lid should fix the problem. If the deck lid is straight, then you'll need to have a body shop fix the car ( expensive). It is also possible the seal is flat, torn, or just worn out - in which case replacing the seal will cure your problem.
Hope this helps!!
Jan 25, 2014 | Cars & Trucks
I installed the retrofit link arm kit and can not close the drawer
The lid seal actuator arms are very complicated to fit back in. It is likely the actuator motors are not set at release position when you fit the arms in. You may need to go into diagnotic mode and select Lid seal on. off function to ensure the both the motors are in release state before you fit the arms back. I am assuming you have a single drawer unit. Not sure why you mention "replaced seals in tub". The lid seal is a single plate.
Dec 18, 2012 | Fisher and Paykel 24 in. DS603H SS...
My Saniplus unit has a very slight leak from the top seal which I noticed when we flushed with the electricity turned off by mistake. I figure this has been the cause of a very slight smell from the unit...
First remove all the piping attached to the unit, remove the whole white box sitting behind the toilet, is only 1 screw holding it to the back of the toilet, then you can remove the 2 screws on top of the lid, pry open the lid using a flat head screwdriver, there is a lid seal in between the lid seal and the pump casing, the lid seal may be kinked or defective which could be the reason why is leaking. You can remove it and re-attach it to make sure is sitting properly. You can also contact Saniflo to order parts.
Nov 19, 2012 | Saniflo & Saniplus& Macerator Pump
My pressure cooker is not sealing. About 10 minutes into the cook cycle, steam and liquid start seeping out of the lid. I've checked to make sure the rubber ring in the lid is in place and restarted it...
I would say that you have a good solution for your problem. The seal could be bad. With the issue of pressure, it does not take much to make a leak. Is the leak in the same place? If so, make a mark on the outside of the lid and when the lid is removed, check the seal at this point. Sometimes it is a dirty seal or a small crack that can be the problem. I am not sure how much a seal costs, but you might want to install a new one.
Joe
Jan 09, 2011 | Vacuums
I can't get the lid back on because of the seal. Can you help?
The lid seal has an opening all around the seal. Make sure the opening faces up inside the lid, there is a groove inside the lid where the lid seal sits in place. Once is placed correctly on the lid, lubricate the lid seal with soapy water and then place on top of the pump casing and just put pressure on the side tabs so it snaps in place. Note that sometimes is required to use a C-Clamp to put the lid back on.
Aug 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
F1 fault code flashing
Inlet hose to inlet valve connection loose
Inlet valve body leak
Damage to the fill or drain hoses
Heater plate damage (chipped enamel)
Seals/O Rings (pinched, contaminated or poor join)
Dispenser (seal, diverter valve or weld leak)
Lid area (lid motors not functioning correctly, lid off
yoke or foreign object interfering with lid seal)
Dec 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The draw does not move smoothly It feels like it is binding. It could be off track or the top could be out of position causing the tight fit.
The track is mono rail and solid to carry the weigh of the tube. If it is off the track then the Tube won't fit inside the housing when moving. I think the lid seal from the top lid touching the top opening of the tube.
1-Check out the lid seal.
2- There is a possibility that the actuate valves went bad. Their functions are to hold down the lid to seal water fromgetting out of the tube during washing, and lift the lid seal up when a cycle is done. If the valves are stuck, the lid seal didn't get released to the upper position causing the friction when the tube moves in and out.
Aug 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The clean dish rinse solution in both drawers leaking out
Your seal aroud the top lid is bad causing the leaking. It is supposed to press down against the groove around the top of your wash tube to seal properly.
1- You need to take it out to inspect the seal, if it flare out, then it need to be replace.
2- If it is OK then your lid actuators on the both sides are faulty. They are supposed to bring the lid down, but either one side is broken then the lid is improperly sealed causing leakeage.
3- The Lid seal is sold in the whole Lid with installed seal together with holders from both sides.
4- The Lid actuators are sold in pair.
Good luck in finding the root cause.
Aug 06, 2009 | Fisher and Paykel DS605I Built-in...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
403 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
