Question about Toshiba 57HDX82 57" Rear Projection HDTV
Convergence problem unchanged after replacing amps, etc.
I've read most of the material posted here on convergence problems and have done the following:
1) replaced the convergence amps - replaced both STK392-110 with -180s.
2) inspected and checked resistors (inline) - all look ok
3) checked pico-fuses - all ok
Convergence is still bad and doesn't adjust.
Please let me know if you have ideas on what I can do next...
The TV is a Toshiba 57HDX82 Rear Projection. It is 6 years old. I have the schematics, a multimeter, and I'm borrowing an oscilloscope this weekend.
History: The TV recently developed the hyper-board disease (video sources were shaky on power-up, then remained shaky, etc.). I had guys from a local shop come out (for $95). They took the big board with them (power and signal) to diagnose the problem. They wanted $300 more to fix it, so I declined and asked them to put it back together. They had a very hard time putting it back together, and the convergence problem began in the middle of this 2 hour struggle. I had the hyper-board repaired (online guy, by mail, $75) and the only problem I have now is convergence. Replaced convergence amps, etc. (see above), and now I'm stuck.
thanks!
Matt
  • 6 more comments
  • mhomiller Aug 15, 2008
    The solution posted refers to an RCA set. My problem statement clearly states that I have a Toshiba TV. Also, the $400 figure I mentioned was for the hyper-board repair (I provided this info for history).
    The second solution posted is not useful either. It referred to the wrong make of TV - mine is Toshiba. And it linked me to a site selling convergence amps... Please read my post!
    Not a solution.
    Please don't respond "take it to a tech". Perhaps the experts that log in during the day have a real solution. Thanks...
  • mhomiller Aug 18, 2008
    Thanks for suggesting things to check. Everything checks out ok, but some of the voltages are off a bit... Please let me know if these voltages are a concern, or if there's anything else I can try.
    The 1.8 ohm resistors measure correctly - there are 3 per convergence amp. Solder joints look fine. I measured continuity from all convergence amp pins to another board connection.
    Voltages Measured at Convergence Amp Pins (vs. Schematic):
    Q751 (Vertical)
    [pin3] -31V (-32V)
    [pin 4] -32.3V (-32V)
    [pin 5] 31.8V (32V)
    [pin 8] -21.8V (-20.5V)
    [pin 10] 22.8V (20.8V)
    [pin 12] -16.6V (-16V)
    [pin 17] -21.8V (-20.5V)
    Q752 (Horizontal)
    [pin3] -31V (-32V)
    [pin 5] 31.8V (32V)
    [pin 8] -16.6V (-16V)
    [pin 10] 22.9V (20.8V)
    [pin 17] -16.6V (-16V)
    I have a picture showing the set's convergence problem, if that is
    useful. Send an email to mhomiller (at) hotmail (dot) com if you want
    me to send the picture.
    thanks...
  • mhomiller Aug 19, 2008
    More comments posted here: http://www.fixya.com/support/t940928-tos...
    As indicated on the other link, I'll probably consider replacing my new -180s with -110s as a last resort. I'm wondering if my -110s were bad in the first place since the set is unchanged.
    Still looking for ideas...
  • 2,323 Answers
I would suggest to measure the voltages -32V on pins 3, 4 and +32 on pin 5 as well +20V at pin 10 and -20V at pin 17 on both ICs. Compare all the voltages that you're measuring to the schematic.
Double check the solder joints on the ICs as well and measure continuity from the pins to where they're connecting to other components. Also make sure the 1.8 resistor are measuring the correctly values.
Posted on Aug 15, 2008
  • Jaime Hernandez Aug 20, 2008
    Thank you for the rating.
    Did you find the data sheets for the STK392-180?
    If you have them you can compare all the specs between both ICs.
    Please keep us posted when you replace the STK392-110.
    Master:
  • 623 Answers
Better take it to a tech
  • 813 Answers
U shoud go with a professinol service parson
  • 1,800 Answers
This sit might help u to find the proper STK392-110 and RCA chaedaper chaedaper !!
i geuss the expert got reason!!
the link1
rate me fixe you!!
    Genius:
  • 1,142 Answers
The convergence is controlled by a separate power supply board and that board needed to be replaced.
take a look at the following web site information. Unfortunately, some RCA sets have manual convergence boards - which means you can do nothing but replace it and adjust the manual controls on the board itself.
But some of the newer ones (Maybe yours) can be accessed through the service mode. So, give it a try. I have also copied the part of the web site that gives the entry code to get into the service mode:
http://myweb.accessus.net/~090/how2adj.html#5.4
5.4 GE / RCA / PROSCAN
Read the _ SERVICE MODE WARNING _ before proceeding.
To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button.
You will now have some information on the screen: "P0 V0"
To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value.
P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.
P4 - 7 control the horizontal size, shift, vertical size and shift.
You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there.
If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
With luck, you MIGHT be able to adjust it back into better alignments.
If you end up needing service, the price of the convergence board - if you can get it from RCA Parts - should not be over $100, but I have not actually checked it lately - and it depends on the model.
The installation is quite time consuming, so it may take a couple of hours for a tech to install and align it.
In my opinion the $400 plus charge is way high. I encourage you to look elsewhere. Also, the RCA web site has a link to authorized service centers; you might try that, also.
Wishing you the best,
  • Maanita Chadha
    Maanita Chadha Aug 15, 2008
    Replace the convergence IC and
    check power resistor for leakage, if values are not exact replace
    them. Once the parts are in place perform the alignment
Mitsubishi WS-65807 convergence - keeps blowing F9A04 pico fuse?
You\'ve already gone a hundred times as far as anyone else within a hundred miles of you, Dave. 8)
It might be the case that something else was borderline & couldn\'t tolerate the convergence being corrected. If that sucker\'s VERY old, I don\'t think I\'d chase it very much farther, myself... you may never get any rest.
Or... it could possibly also be the case that you overheated a lead on one of the ICs. They can\'t tolerate very MUCH heat - barely enough to get it hot and get it done. Especially if you soldered the leads sequentially instead of alternating like Pin 1, Pin 14, Pin 2, Pin 13, etc.
If the ICs were\'t very expensive, you might try it one more time - ICs and picofuse. Take every precaution not to overheat the IC leads. If it doesn\'t work THIS time, donate it to a good cause unless you simply like challenges.
Aug 07, 2014 | Mitsubishi Televison & Video
How Do I fix the convergence on my 2001 Hitachi Projection Tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 05, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Someone has stolen my id has changed screenery & many super bright colors i can't read it i not sure i can receive my e-mail .i keep changing my pass word,not helping
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Dec 17, 2010 | Philips 55PP9363 55" Rear Projection...
Philips 46pp930217f convergence problem
Goto www.TvRepairKits.com and get a complete kit with instructions. Of get them from parts suppliers -but watch out for clone chips - only get OEM originals - avoid Ebay
Mar 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
My convergence problem is the green convergence missing in menu
the only info you need is to replace the middle chemical fuse next to the flyback, I believe it`s marked "231" on most sets and then the critical parts is to re-solder ALL of the pins on the flyback transformer, 9,10,11 are usually cracked big time but you need to solder all of them, I`ve done this 50 times and never had a call back, gl, video-tek
May 29, 2009 | RCA HD52W59 HDTV Projection Television
Blue lines will not line up
  • Screen looks 3D
Apr 16, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Blurry edges, white objects too bright, glowing
  • Screen looks 3D
Mar 16, 2009 | Philips 51PW9363 51" Rear Projection...
43 philips problem with green
  • Screen looks 3D
Jan 24, 2009 | Philips 43PP9202 43" Rear Projection...
Power up issues
Bad new convergence amp IC's......What part # did you use
and what quality were they ?................read some of my
convergence repair solutions........................T.
Mar 06, 2008 | Philips 50PP9202 50" Rear Projection...
How do I replace the convergence board in this unit?
Yes the board can be replaced, but you may also need to do some touchup alighnment to the convergence, and maybe need to reprogram the magic focus or whatever the ato convergence is called on your set, if it has that feature, Good Luck
Jun 08, 2007 | Samsung PCN5425R 54" Rear Projection...
Toshiba 57HDX82 57" Rear Projection HDTV Logo
178 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
