Question about Rheem M206A 206K BTU Pool and Spa Propane Gas Heater
My pool heater turns on, but cuts off after a few minutes saying "clean filter/strainer pool service" or something to that effect. I understand from my manual that this may mean that there is insufficient water flow through my heater. I have cleaned my filter, pump basket, strainer, etc., but the heater still won't stay on. Water is rushing normally through my skimmers and my pump pressure is normal. So I don't believe that there is insufficient flow through the heater. I am afraid that my heater might be dirty inside or something. Could this be the case? Sometimes the "fault code" is "IGN." I have tried cutting it off for a while then cutting it back on, but it does not work. Ideas? Can this be fixed without a service guy? Our pool party starts in one hour. Thank you.
    Top Expert:
  • Rheem Master
  • 6,949 Answers
Check pressure switch if ok and voltage ok or check line to switch
Posted on Oct 11, 2017
  • 13 Answers
SOURCE: My water heater is brand new. Last night was the
code 21, Check the Air Intake Filter switch, you can press that switch from outside. The filter cover may not be properly seated.
Posted on Feb 12, 2010
SOURCE: Error code 13 (air flow) tankless H20 Rheem
Have 2 of these Rheem units in my house. Both had this same error code within 30 days of each other. And my neighbor has 2 units as well - and guess what - 2 months after mine stopped working because of the code - so did theirs. It is not something that can be fixed. It is a manufacturer's defect - and it looks like Rheem has yet another class action on their hands (like the one for the RTG - 74 PVN). They need to do a recall to repace these units.
Posted on May 08, 2010
  • 990 Answers
SOURCE: pool pump shutting down -- heater?
Trying to get the TA correct before you kill the alge? Leslies diagnosis?
You probally just need to kill the alge before you do anything. Nevermind the TA for now and just add about ten gallons of liquid chlorine. The alge untill you kill it will plug the filter constantly. This will give you the code on the heater and will make the pump run very hot and will hurt the plumbing by shrinking it. This will stop water flo by letting air in also it will leak water at the pump discharge.
A lot of liquid will break the alge as it is unstable, but use a lot.Once you kill the most of the alge then add probally another four gallons and now brugh the whole thing real good. now you can start running again and start with all the stuff they will sell you to adjust the PH and TA. I hope this helps, and good luck.
Posted on Jul 14, 2010
  • 990 Answers
SOURCE: clean filter/skimmer service error.
You have a low water pressure problem. Once you clean the baskets and filter you will need to check for plugged lines on your suction and for a clog in your impeller on your pump. If your pump basket is cracked the impeller is the place to start. Reach into the pump, with the basket out go through the hole in the back of the pump pot with some long nose pliers and feel for anything in there. If you can't pull it out with the pliers then break the pump down and see if you can clear it then and run a wire through the veins on the impeller. Then if it still has problems you may have to replace the pressure switch on the heater. This is seldom the problem, it is more of a warning to tell you of the other things that may be wrong.
Posted on Oct 07, 2010
john224
  • 1378 Answers
SOURCE: My pool guy had turned off the remote feature of
The clock indicator means the firemans switch is open. If you are running the heater remotely and thru a time clock the time clock is still off. Turn all the equipment on including the timer and you should be able to put the heater into remote mode.
If you still have trouble, please comment with your actual model and serial number from inside the heater.
John
Posted on Nov 05, 2010
Pentair MasterTemp 250 Natural Gas Heater with "Service System" issue
this heater will display 2 red light related problem 1-service the system mean you need to clean you filter, and service the heater mean it may be a problem with the heater this 2 you will be able to see it in key pad control the heater ,now reset the board and see what happens (CUT THE POWER ON/OFF UNCE )
Jun 09, 2013 | Pentair Pool & Spa
My pool heater rheem said clean filter and strainer. not turning on heat what should i do..to solve the problem and tell me how do i clean the strainer where it is location...
They are referring to the strainer basket inside the filtration pump, and the pool filter system itself. The indication is either this basket is full of debris or the pool filter is so dirty you do not have enough water flowing through the heater. A safety device in the heater is shutting down the heater to prevent damage. None of the parts you named are inside the heater.
Jul 18, 2011 | Raypak RP2100 DIGITAL POOL HEATER R206...
My pool heater turns on, runs a few minutes, the igniter lights and the heater heats for about 3 minutes, then turns off. I see a SERVICE comment blinking and SW2 is also blinking.
im not sure what filter you have on there but do a good cleaning if its D.E acid wash it if sand clean the sand. your not keeping enuff pressure to keep it lite. take it slo
Oct 15, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Prs error code, clean strainer
Your not getting enough pressure to run the heater. So you need to clean the strainers and clean the filter. If you have a DE filter you may want to break it down and clean it. While your at this you should check your pressure switch and your by-pass valve.
Sep 06, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heater not working -
Check the pump strainer basket for debris and see if the pressure is high on your filter. If so, backwash time. The "filter: error is usually restricted flow...
Jun 18, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
What do you do about a service strainer notification on a rp2100 digital
Clean the strainer basket on your pump and clean your filter. If this does not help you will need to check your impeller expecally if your basket has any cracks in it. Also if you have a by-pass valve between the inlet and outlet pipes going to the heater that should be 80-90% closed. Hope this helps, good luck.
Jan 23, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypack gas pool heater displays"clean filter/strainer" when I turn it on
There is not enough system pressure to close the heaters pressure switch so the heater will not fire. Assuming your pump is on and any valves in your pipes are set correctly it means something is restricing water flow too much and needs to be cleaned to fix your flow rate and allow the heater to fire.
Start at the skimmer(s) baskets and then the pump strainer basket and finally clean your filter. If sand, backwash it. If cartridge or DE clean according to your manufacturers direction. In some cases cleaning a cartridge filter will no longer satisfy heater pressure requirements meaning you will need to replace the element.
Nov 11, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Says clean filter strainer
Could be the pressure switch on the heater. Jump switch. If heater fires the switch is bad
Jul 11, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
I have Hayward earth filter for the pool along with a Pentair Mini Max 100 pool heater - first time starting both for the season and the filter motor is making a straining noise. For the few minutes its...
make sure all vents are clean check to see if there is anything stuck in impeller with pump off take straner basket out look at opening going back to filter is water filling the strainer basket
Jun 17, 2009 | Hayward 1.5 Hp Northstar High Performance...
Rheem M206A 206K BTU Pool and Spa Propane Gas Heater Logo
141 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
