Question about Galileo Digital Binocular Camera
GGRBC: Supporting software available for a Mac? Using OS 10.6 and Snow Leopard. Thank you.
Tip
How To Upgrade Mac OS X Tiger 10.4.* to Snow Leopard 10.6.*
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the <a href="http://www.amazon.com/Apple-MC581Z-A-Mac-10-6-3/dp/B002I0JKE2">10.6 Box Set</a>.<br /> <br /> <span style="font-weight: bold;">System Requirements to run Snow Leopard:</span><br /> <ul> <li>Mac computer with an Intel processor</li> <li>1GB of memory</li> <li>5GB of available disk space</li> <li>DVD drive for installation</li></ul> <span style="font-weight: bold;">Snow Leopard Installation Instructions:</span><br /> <ol> <li>Just insert the DVD in the optical drive.</li> <li>Restart your Mac while holding down the C key.</li> <li>You will be guided through the installation procedure and be prompted at one point to choose which install option you want.</li> <li>Once the Snow Leopard install is completed the Mac will restart itself.</li> <li>You will probably be asked to register with Apple upon restart.</li> <li>Enjoy Snow Leopard on your Mac!</li></ol> <b>Q: Can I upgrade directly from Mac OS X 10.4 (Tiger)?</b><br /> <br /> <i>A: Yes. Apple recommends purchasing the Mac Boxed Set for this purpose, which will also update iLife (it is unknown at the time of this writing whether older versions of iLife work with Snow Leopard) and iWork. Also note that while it has been said that the $29 upgrade will work with 10.4, it is not officially supported and may be in violation of the licensing terms.</i><br /> <br /> <b>Q: What happened to the different install options? Can't I do an Archive & Install?</b><br /> <br /> <i>A: Apple has revamped the familiar installation options for Mac OS X. You now have two choices, either a straight upgrade or a clean install. Supposedly if you choose to do a straight upgrade, what actually goes on behind the scenes is what was traditionally known as an Archive & Install.</i><br /> <br /> <b>Q: Is there anything I can do to better prepare myself for the upgrade?</b><br /> <br /> <i>A: Yes. It is advisable to run a Verify/Repair Permissions and Verify/Repair Disk in Disk Utility. You may also want to run the maintenance tasks in <a href="http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html">Onyx</a>. And finally, it would be wise to get your applications up to date using a program like <a href="http://metaquark.de/appfresh/">AppFresh</a>.</i>
on Feb 16, 2011 | Apple Mac OS X
Tip
How to set Mac OS X 10.6 (Snow Leopard) to run in 64-bit mode
There are two ways to set Mac OS X Snow Leopard to run in 64-bit mode.
The first way is quite simple: you just have to hold down "6" and "4" keys while the system is booting up.
The second way is simple as well. You only have to search for a file named "com.apple.Boot.plist" in /Library/Preferences/SystemConfiguration. Open it with Text Editor and edit line 9: where it reads "<string></string>", change to "<string>arch=x86_64</string>". Without quotes, of course.
Using the second way, Mac OS X Snow Leopard will boot in 64-bit mode whenever you turn on your computer.
PS: 64-bit mode is available just in some machines like MacBook Pro and Mac Pro. To check if your Mac supports 64-bit mode, write the following command in Terminal, again without quotes: "ioreg -l -p IODeviceTree | grep firmware-abi". You will get the answer "firmware-abi" = <"EFI64"> if your system can run in 64-bit mode or "firmware-abi" = <"EFI32"> if not.
on Apr 10, 2010 | Computers & Internet
How do I upgrade to 10.5 or .6?
Firstly you will need to buy a copy of 10.6. This is available from Apple (see link below) or you could get a copy from eBay.
Mac OS 10 6 Snow Leopard
The following article will tell you what to do next:
An Easy Guide to Installing Basic Upgrades in OS Snow Leopard 10 6
May 29, 2012 | Apple Mac OS X 10.4
Hi, Went to the Mac store to upgrade to Snow Leopard and was told my OS was "way too Old to upgrade to Snow Leopard!" Sorry, I'm a numbskull when it comes to these things. Figured as long as...
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the 10.6 Box Set.
  • Mac computer with an Intel processor
  • 1GB of memory
  • 5GB of available disk space
  • DVD drive for installation
  1. Just insert the DVD in the optical drive.
  2. Restart your Mac while holding down the C key.
  3. You will be guided through the installation procedure and be prompted at one point to choose which install option you want.
  4. Once the Snow Leopard install is completed the Mac will restart itself.
  5. You will probably be asked to register with Apple upon restart.
  6. Enjoy Snow Leopard on your Mac!
A: Yes. It is advisable to run a Verify/Repair Permissions and Verify/Repair Disk in Disk Utility. You may also want to run the maintenance tasks in Onyx. And finally, it would be wise to get your applications up to date using a program like AppFresh.
I want to upgrade to safari 5. can i do this and is it free?
Yes Safari 5.0 is free for download from Apple website for MAC PC's.
There is no charge and you can do it.
You can download it on your PC if you have the update or click on the link below to download download the safari 5
Safari 5
Thank you for contacting FixYa
*Please rate this solution with thumbs up
Nov 23, 2010 | Apple safari
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
I have upgrades to Snow Leopard on my iMac and cannot access the printer commands to cheque the printer heads, and ink levels.
You can find useful information on site? http://www.epson.com/cgi-bin/Store/support/SupportSnowLeopard.jsp Mac OS X Snow Leopard Support Contact Support rightmenudottedline.gif snow_leopard_logo_sm2.jpg Welcome to Mac OS X Snow Leopard v10.6 support for Epson products. Here you can find out how to get drivers and other Epson software for your Epson product that work with Mac OS X Snow Leopard v10.6.
Check your Epson product CD to see if it already contains Macintosh OS X 10.6 drivers. If the CD indicates support for Macintosh OS X 10.6, follow the instructions that came with your Epson product to install your drivers and other software.
If your Epson CD does not indicate support for OS X 10.6, DO NOT INSERT YOUR EPSON PRODUCT SOFTWARE CD IN YOUR SNOW LEOPARD COMPUTER. Follow the step-by-step instructions below to obtain the latest software and utilities for your Epson product as they may be needed for this new operating system.
Good Luck.
Nov 03, 2009 | Epson Stylus Color 777 InkJet Printer
I cannot find a Canoscan N1220Udriver for Mac OS
Canon has indicated that N1220U will not be supported under Mac OS X 10.6.x (Snow Leopard). The only practical way to continue using the scanner under Snow Leopard is to buy the third party scanner software, VueScan (US$39.99).
Sep 29, 2009 | Canon CanoScan N656U Flatbed Scanner
Need driver for Apple Snow Leopard with spc210
Ricoh directs all users to Apple to review this link (below)to determine if their Ricoh printer meets Snow Leopard compatibility.
Ricoh Printers Supported for Mac OS X v10.6
If you find that your printer is on the supported list,
then you can download the driver software for Snow Leopard on the Apple Support site.
Here is the Apple Support Link:
Ricoh Printer Drivers for Mac OS X v10.6
If you do not find your printer is supported, then unfortunately this driver download will not work for your printer in Mac OS X Snow Leopard.
Regards,
-Mactechtrainer
Sep 28, 2009 | Ricoh Aficio SPC210SF All-In-One Laser...
Galileo Digital Binocular Camera Logo
29 people viewed this question
Top Galileo Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
NOEL
NOEL
Are you a Galileo Optic Expert? Answer questions, earn points and help others
