Question about Hitachi DV18DCL 18V 1.5Ah Lithium-Ion Hammer Drill
Where can i get a new switch for a DV18DCL - Hitachi DV18DCL 18V 1.5Ah Lithium-Ion Hammer Drill
  • 8,197 Answers
How to fix power switch?
you need the following tools
soldering iron, solder, grounding strap ground the unit and you.
soldering plunger to remove old solder, the right switch, buy a new switch, solder,
disassembly the unit, find the broken switch unsolder, clean contact area, solder new switch, with out over heating the board or new switch, reassembly, test, your done
Oct 02, 2015 | Tablets & eReaders
Fix 3way switch
Feb 2013
1) Copy following link for 3-way switch wiring
http://waterheatertimer.org/How-to-wire-switches.html#3-way
http://waterheatertimer.org/images/Switch-quick-connect-400.jpg
2) Usually a bad switch is replaced.
Buy another 3-way switch.
New switch will have 3 screws (plus green ground screw which is not discussed further).
On new switch, 1 screw will be different color from other two screws.
Same thing with old switch: 1 screw will be different color.
Take wire on different color screw and connect to different color screw on new switch.
Other two wires can connect to either screw.
Feb 02, 2013 | Electrical Supplies
Hitachi Cordless Impact Driver gearing problem
The speed shift slider switch wasn't lined up correctly when the unit was reassembled.
Unfortunately, you going to need to repeat the disassemble/reassemble process once more.
I've been there. It doesn't take much to be out of alignment. Set everything to the lowest setting (clutch, speed) and take your time.
Best regards
Mike
Apr 22, 2010 | Hitachi DV18DCL 18V 1.5Ah Lithium-Ion...
Need to move a light switch into a new room, I had a big den that I closed off part of to make another bedroom. the problem is the light switch for the light is now in the hallway.
this cannot be easily answered, if the power supply is in the fixture simply run a new wire to the new switch. if the power is in the switch run a wire from the same switchbox to the new location and wirenut the wires on the switch to your new wire. remove the switch to the new location and ummy off your old switchbox.in either case the latter should be the easiest and safest way to go. always be sure to turn the power off at the panel box. and remember electrical work isnt like your typical trades bad things can happen when very quickly if you dont know what you are doing.
Dec 29, 2009 | Electric Door Light Switch
Hi there, we have replaced dual infinite switch on our jennair range and cannot figure out the correct wiring for the new 12002125 switch....can you help...???
Follow the instructions below from partselect:
Attach the black wire(s) from the old switch (terminal 2) to the new switch terminal P1. Also attach the jumper cable to P1 and "jump" it to S1.
Attach the orange wire (old switch terminal 5) to S2
Attach the yellow wire (old switch terminal 4) to 4a
Attach the tan/(white?) wire (old switch terminal 3) to terminal 4 on the new switch
Attach the single red wire from the right front element to terminal 2 on the new switch.
Attach the 'compound' red wires (the ones that come from the left rear/outlet connection and is also attached to the right rear switch) to terminal P2 on the new switch.
There is no need to separate the compound red wires.
Best regards.
G.
May 28, 2009 | Kitchen Ranges
Installation How To
Installing the new switch is fairly simple. Connect the two hot (black) wires to the two brass terminals on the new switch. Gently push the new switch back into the box. Fasten the switch to the box with the two long screws at the top and bottom of the switch.
Aug 27, 2008 | Gen Tran 12-Circuit Hard-Wired Transfer...
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
New Computer Won't Switch Back
can you reprogram the KVM switch to use different keys?
Dec 03, 2007 | Belkin F1DL102P 2-port KVM Switch
Hitachi DV18DCL 18V 1.5Ah Lithium-Ion Hammer Drill Logo
59 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
