Question about Peg Perego John Deere Gator HPX Ride on Toy
We've just built my sons gator and plugged the charger into a socket which was attatched to the battery and it blew all the fuses in the house. The charger plug now has scorch marks on and won't work. What can I do? is there a fuse in the sealed plug or do I need a new one?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Probably going to need a new one, you can plug the charger in with out it being hooked up to the battery and test it with a multimeter to make sure that its putting out 12 volts
Posted on May 16, 2012
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
  • 156 Answers
SOURCE: john deer push pull tractor won,t work.
If you have a clicking problem, I would check the wiring on the foot pedal. something is not connected right, which is making the fuse click.
You can contact J&L at this link or call there toll free number. http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have switches and other parts for these peg perego gators, but I would talk to them to make sure.
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: I'am Looking for a diagram for a Plunger Fuse onthe gator 4x2
The wire sequence is red, white, blue.
The red is the farthest from the other two.
If it is a peg perego switch plunger style then this will work.
Hope this helps
Posted on Jun 23, 2009
  • 156 Answers
SOURCE: where does charger plug in gator
The Peg Perego Gator Battery is located in front behind the black gril and green battery door
  • 156 Answers
SOURCE: We bought a new battery and new charger and still
I would replace the high/low switch and reverse switch. You can get them at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html They also have repair help to figure it out as well. hope this helps
Posted on Sep 14, 2009
My cigarette lighter keeps blowing out the fuse fir it I've put in a 20amp n that blew out when I plugged in the charger n put a 30 amp that work for a couple hours n put the charger back again in it...
Never put in a bigger fuse than what it calls for. You must have a bad socket that is shorting out or the item you are plugging in is shorting it out.
Aug 03, 2011 | Chrysler Sebring Cars & Trucks
We have a Peg Perego John Deere tractor that won't go. We've tried recharging the battery but it still doesn't work. The last time it was used, my son was repeatedly pushing the accelerator...
check the battery with a multimeter and make sure you are getting at least 12 volts, if its not showing any voltage one of the wires from under the plastic housing has become disconnected, if it is showing voltage but not 12 volts recharge it then check it again after about 12 hours and make sure it is showing 12 volts, if it isn't check your charger with a multimeter and make sure that its putting out at least 13.8 volts, if it is then you have a bad battery
Jul 15, 2011 | Peg Perego John Deere Gator HPX Ride on...
Gator won't go. I've replaced the foot pedal and the battery. What's next?
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 10, 2010 | Peg Perego John Deere Gator HPX Ride on...
My Peg-Perego John Deere Battery Powered Gator HPX will no longer drive
Sep 08, 2010 | Peg Perego John Deere Gator HPX Ride on...
My sons john deere gator is dead do they send new batteries or chargers for it
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in, otherwise you can order a new one here www.powerwheelsoutlet.com
Sep 05, 2010 | Peg Perego John Deere Gator HPX Ride on...
My son had peg perego 4 wheeler electric and I had extra battery He only 1 cricle around the house and it stop even battery been charge please help
Aug 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
The gator was running and just stopped. I checked all the wiring and recharged the battery. It will not go in any gear. I also checked the fuse.
Aug 28, 2010 | Peg Perego John Deere Gator HPX Ride on...
Gator wont run put new battery in.last summer would work fine
Jun 30, 2010 | Peg Perego John Deere Gator HPX Ride on...
Plug battery into charger light goes out
Apr 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
140 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
