Question about Baxter BXM-BXP283FLR Roll In Double Wide Proofer Cabinet With Flooring 83 Interior Space
No heat from all three heating elements in a baxter proofer. fuses? sensors? any thoughts? thank you bakery owner
  • If the solution below checks out there are further steps you can take. Remove the top trim of the oven to access the control box. Remove the cover and you should see a control board a couple relays (maybe), and two large 3 pole contactors. Verify that the right contactor pulls in when you turn on the proofer and the left contactor should cycle on and off roughly every 20-40 seconds. If you know how to use a multimeter check for voltage on the left contactor on the connections marked A1 and A2, if you have zero volts for more than 40 seconds your relay board could be faulty if you get voltage but the contactor doesn't pull in then you have a faulty contactor. When replacing any parts make sure to turn off the power before servicing, these proofers have two separate power supplies.
  • 416 Answers
Check Electrical Box. The interior lights work on a separate fuse in the panel. Flip it all the way off and back on and try again. If nothing still, select one or both of the following options.
  1. Access the wall socket where the unit is attached. test the socket with a multi meter. You should get 210-230V ac from placing the leads in left AND right receptors. Placing a lead in the left OR right receptor AND the bottom ground should 110-130-V ac. If you do not have these readings stop now and do not plug your unit back in.
  2. Go to the service panel and identify the dual pole high voltage breaker for your unit. There should be a cable with 4 wires together, two to (one to each of) the breackers, one to the neutral bar on the small bar with insulated copper wire attached, and one with naked copper wire for the grounds. Make sure these are all connected properly as your unit may work with the wrong amount of power or a while but with ultimately burn up some high energy elements
Posted on May 21, 2011
My oven heats but it took 20 min. to preheat to 450 deg. today. The problem could have been for several days. I thought it either heats or not heat at all. Could it be the element. Also, when baking,...
no the broil also heats up,depending on the model you have it could be a problem with the element but if it heats sometimes i don't think it will be the element it could be the thermostat or sensor or a board issue depending on the model you have.you need to get in there with a meter to check out if you're getting 240 volts to the element,the broil element get 120 volts,but the only way to tell is with a meter.if you have fuses in the house instead of breakers check the fuses,you could have a bad fuse and only be getting 120 to the bake element.if you go to remove the element to check it with a meter make sure you kill the power to it or you can damage something else.but checking the elements is a good place to start
May 11, 2011 | Whirlpool Kitchen Ranges
I have a Maytag Atlantis dryer with intellidry sensor. it will not heat up enough to dry clothes - it just is slightly warm. The sensor always says "damp"
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things - thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in plastic housing. If that’s fine then the Heating Element should be checked. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 14, 2010 | Dryers
Wont heat
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Apr 06, 2010 | LG DLE7177 Dryer
Fridgidaire dryer model aeq7000eso isn't heating
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Mar 18, 2010 | Frigidaire AEQ7000ES Dryer
GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 23, 2010 | GE DCVH515EF Electric Dryer
Does not heat- three of the temp sensors read 0 ohms, one is at 7.4 K ohms. Can it be the cause
Hello there
Here is a list of item for you to check Hope this is very helpful for you
Best regards Richard
My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
Dec 15, 2009 | Whirlpool LTE6234D Top Load Stacked...
2000 Lincoln LS front heated seats are not working. Could it be a fuse?
could be a fuse or could be heating element.. if you have owners manual then look in the back for fuse diagram.there are three fuse panels.front passenger footwall under the hood right front and at the battery in the trunk
Oct 14, 2009 | 2000 Lincoln LS
THE DRYER STOPPED PRODUCEING HEAT.
Check the following to address the non heating issue
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 01, 2009 | Kenmore 73952 Gas Dryer
Baxter BXM-BXP283FLR Roll In Double Wide Proofer Cabinet With Flooring 83 Interior Space Logo
57 people viewed this question
Top Baxter Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Baxter Refrigerator Expert? Answer questions, earn points and help others
