Where does the wires go in my winfast motherboard
    Sergeant:
  • 167 Answers
Try to connect via USB or printer slot at the back of your pc
Posted on May 21, 2011
Motherboard
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
What you are asking for is a Front Panel header pinout.
I do not have the exact Front Panel header pinout, for your motherboard.
Tell you what I do have though..........
Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.
(Motherboard installed in computer case)
Black rectangular strip of plastic, with contact pins sticking up.
Also looks to be a GENERAL set-up for all Winfast motherboards.
(COULD be wrong here)
This is what I am referencing off of,
http://www.devhardware.com/c/a/Motherboards/Foxconn-Winfast-NF4SK8AA8EKRS-Motherboard-Review/3/
Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.
(Below round CMOS battery)
Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.
(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)
Now look at this Front Panel header pinout, for another Winfast motherboard,
http://www.techsupportforum.com/forums/f15/winfast-mobo-front-panel-connection-558456.html
(Scroll down a little)
PWRLED is for the Power On LED (Light)
PWRSW stands for Power On switch
HD-LED stands for the HarDDrive activity LED (Light)
RESET stands for a Reset switch, IF USED.
Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.
This is the pin the + wire from the Power On LED connects to.
It is the SAME for every LED that connects to the Front Panel header.
Let's number the contact pins, to make the explanation easier;
Starting at the Left side, Top row; going towards the Right;
Pins 2, 4, 6 and 8. There is NO Pin 10.
Starting on the Left side, Bottom row; going towards the Right;
Pins 1, 3, 5, 7, and 9.
Pin 2 is for the Positive wire.
Pin 1 is for the Positive wire
If the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.
(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)
There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;
Use an LED with two wires
Computer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.
Example; Pins 2 and 4, as shown in the pinout.
Did the Power Supply come on?
No?
Go to the next two pins. Try again.
When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.
DO NOT touch them again. In fact connect the Power On switch wires.
Power Supply on, computer running;
Now go back along again;
1) LED light blinks?
You have the HarDDrive activity LED, contact pins.
2) LED light stays on?
You have the Power On LED, contact pins.
3) Computer restarts?
Those are the Reset switch, contact pins.
4) Nothing happens?
May be contact pins for a speaker, or contact pins that are not used.
(Speaker is for hearing BIOS Beep Codes.
You have a Piezo buzzer, to the Left of the CMOS battery; for that)
Post back in a Comment, as to the results.
If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.
That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 30, 2013 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
WHERE DO I CONNECT THE PWER SWITCH PIN ON WINFAST MOTHERBOARD
hai, i am using winfast motherboard pc and i was remove my cpu all wire so please tell me about how to connect the power switch wire and restart wire
Oct 28, 2012 | Foxconn WinFast K7S741MG Motherboard for...
Winfast 64100
Try the manufacturer's website.
Get online and got to www.google.com In the google search box type: "Winfast Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals throughout the site.
Jun 06, 2012 | Computers & Internet
Winfast pc760m02-gx-glrs motherboard layout
Read the manual and it will tell you the process.
Get onlineand got to www.google.com In the google search box type: "WinfastSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals throughout the site.
Jun 05, 2012 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
I have a Winfast K7S, 741M01C, series motherboard
Hello Friend,
The max RAM that you can use with this motherboard which has 2 RAM slots is 2GB.
Best Regards,
Oct 30, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Compatible CPU
check the winfast website for a cpu support list for your model of motherboard, that will tell you if it supports it and ALSO if you need to update the bios to support later cpu's, i'd imagine your using the old socket A standard, see if your motherboard is listed here> http://www.leadtek.com/eng/mainboard/default.asp?lineid=3&seriesid=23&chipseriesid=15 (this is what is now listed in google as winfast and does show winfast boards), please advise if you get stuck anymore.
Sep 22, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Nead motherboard oweners manuel
Goto the web page and download it from there.
Apr 01, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
