Question about Sport & Outdoor - Others
Rewind fishing line on a spinning reel - Sport & Outdoor - Others
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
Benimur
  • 6966 Answers
SOURCE: penn fishing reels
For a Penn GTO 220, pls check this page an exploded view of the GTO220 that details parts and their placement. It is a PDF file and would need Abobe Acrobat Reader to view and print.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
SOURCE: I do not know how to thread line through reel
put spool of string on a pencil and have someone hold it, now snake the string through the eyes of the pole and attach it to the reel, on the small shaft in the middle, then just reel your pole in untill you reach YOUR limit of string..
Posted on Mar 07, 2009
  • 302 Answers
SOURCE: How to I fix a spin casting reel?
You should be able to remove the spool by removing the knob on the front of the reel which also is the drag adjustment. With the knob off the spool should pull right off. Hope this helps you
Posted on Oct 19, 2009
  • 12 Answers
SOURCE: ladyfish fishing pole by shakespeare
try switching sides of the handle by holding the bell and reeling then screw it in on the other side of the real by just reeling in. If that doesn't work then take all the line out and reel in some new line the opposite way.
Posted on Jul 29, 2010
What causes the fishing reel to skip teeth when retrieving line?
I went fishing with a commercial fisherman. I had a freshwater spinning reel and we were fishing for mackerel and Pollack. He told me pulling fish upwards from the bottom would damage the teeth on the retrieve because a spinning reel is designed to pull fish towards you at an angle, whereas in boat fishing you are hauling from below. After bringing up 3 lots of line with 4 to 6 mackerel on feathers, the teeth started to skip. He said "I did tell you". I wasn't too worried as it was a very cheap reel. The next week I bought a Penn 10 which was what he recommended.
Basically you have stripped the ends of the teeth. Depending on the quality of the reel, you may be able to get spares, or otherwise you upgrade.
Mar 31, 2016 | Fishing
Tip
Top 10 Best Spinning Reels for 2016 & 2017
Let's face it! It is not easy to find the best Spinning Reel from the market.http://www.topspinningreels.com/ here you find your best spinning reel.When you are looking for a Best Spinning reel, you'll see that numerous brands have a few reels with the same name that come in various sizes (for instance a 100, 200, 400). This is typically in light of the limit of the spool, which directs the general size of the reel.In this video you will see 10 unique models of awesome quality modest turning reels. After quite a while of research, survey and searching for reels data I made my own rundown of main 10 minimal effort turning reels in slideshow design. My rundown incorporates every one of these reels.
Enjoy Our top 10 best spinning reels to buy for the 2016 & 2017 Fishing Season. The Lowest Prices Online!
Visit our website: http://topspinningreels.com/
1. PENN Spinfisher V Spinning Reel
2. Penn Battle II Spinning Reel
3. Daiwa Mini System Minispin Ultralight Spinning Reel
4. Shimano Stradic CI4+ Spinning Reel
5.Okuma Avenger ABF Graphite Bait Feeder Reel
6. Pflueger President Spinning Reel
7. Okuma Trio High Speed Spinning Reel, Black/Orange
8. Abu Garcia BMAX2 Black Max Baitcast Reel
9. Zebco Omega ZO3PRO Spincast Fishing Reel
10.Penn Clash Spinning Reel
on Nov 24, 2016 | Fishing
Tip
What to Consider When Buying the Best Inshore Spinning Reel
Best Inshore Spinning Reels Review Buying Guideline
When deciding on which fishing reels to buy, there are some points that you need to consider for you to end up with the best inshore spinning reel. A good spinning real can make all the difference in your fishing experience.
5 Best Inshore Spinning Reels Overview
How to buy a fishing reel
Depends on what type of fishing your doing. Out of the two the bait caster is the more challenging to do because you control the line going out. That is good for fishing banks, logged areas, spinner bait. If you just want to cast with bobber go with open or closed reel. Hope that helps.
Aug 21, 2014 | Fishing
Tip
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Sport & Outdoor - Others Logo
98 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
