Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
My Bissell Little Green won't spray the solution. The suction seems to be working fine and the lines are all connected as they should be. What's up and how can I fix it?
  • 3 more comments
  • Anonymous Sep 22, 2008
    Same problem here. I even took everything apart to make sure the lines weren't clogged, but it won't spray. I don't think I'll buy another Bissel.
  • Anonymous Nov 17, 2008
    same problem here
  • skinnyhuen Dec 18, 2008
    Same problem. I can't find any clogs.
  • Anonymous Jan 11, 2009
    Same Problem Here!
  • darat Feb 21, 2009
    It will no longer spray. Have taken apart and cleaned line but still no spray.
I also had the same problem as you.
Try suctioning up a full tank of hot tap water into the collection tank to soften/release a possible kink in the tubing inside of the vacuum hose that carries solution out to the spray tip.
I did this a couple of times and it worked. This info I found on the Bissell website.
Good Luck!
Posted on Apr 01, 2009
My Bissel Little Green had exactly the same problem. In mine is was not a plugged hose. The motor had seized.
Fortunately it is a ver easy problem to fix. The motor is actually fine quality .... it is the cheap grease they use for the water seal that yellows and hardens seizing the front bearing. Remove the grease spray with WD40 or spray lithium grease and remove the grease residue. Then regrease with a water proof grease like Phil's. Even with good grease this probably needs to be done every year or 1/2 year. (they don't tell you that in the manual do they)
ABOVE ALL.
DON'T RUN THE UNIT WHEN THE SPRAY DOSEN"T COME OUT .......... Thay will fry any motor on about 1-5 min because it isn't turning or coolling.
ALSO Don't service with the unit plugged in.
Posted on Sep 04, 2010
Mean green little bissells will not discharge or pick up water
Hi Carolee. I know how frustrating this must be. We have some really great FAQ's on our website that will help you resolve the spray and suction problems.
Here's a quick link to assist you: http://www.bissell.com/faqs/?cid=ccsocial
Mar 26, 2013 | Vacuums
Won't spray solution
if its not spraying solution there are two possible problems,
1. the solution carrying line that runs from the unit along inside the hose could be blocked.
2.there mite be a clog somewhere inside the solution tank or leading from the solution tank
Sep 19, 2012 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
WILL NOT SPRAY. i CHECKED THE LINES AND THEY ARE
I had the same problem, then I read somewhere that you have to prime it before you turn it on, to help it regain suction...before you turn it on hold down spray button for about 1minute, then turn it on and use it. Solved my problem...good luck!
Jun 17, 2009 | Bissell 1425 Little Green ProHeat Handheld...
Cleaning the bissell little green
Bissell 1425 works great, but today will not ****! Spray is fine....just no suction, even without any attatchments.
Oct 11, 2008 | Bissell 1425 Little Green ProHeat Handheld...
Won't spray
your pump is bad.i have one doing the same thing.everything works fine except it won't spray,just dribbles
Aug 03, 2007 | Bissell 1400 Little Green Pro Canister...
Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
1,445 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
